if you have Rainloop enabled, disable that first.
I disabled the Rainloop Client and the passwords worked!
Yes disabling rainloop did the trick. Special thanks for mdw.
Could you mark the latest response by mdm as âSolutionâ? This helps others find the right answers quickly
Hi!
Not solved as I do not have âRainloopâ or âSnappymailâ installed and âPasswordsâ still not work. I get a red warning in the (windows) client (firefox):
Expected Application JSON, got text HTML:
Nextcloud 27.1.4, Passwords 2023.11.30
Mv Stefan Sundberg
Then you donât have this issue which was solved by disabling Rainloop.
Please open a separate thread with the details about your specific issue.
disabling Snappy Mail worked for me as iâm still using Rainloop
