I´m using the most recent versions of Nextcloud (11.0.2) and Collabora CODE (2.0.4) docker container on Debian Jessie.
I always had the problem that I only got a grey frame when I tried to open a document. With the help of annother post in this forum I found out, that Debians Apache configuration causes the problem.
To be more specific, the issue is the “Header set X-Frame-Options: “sameorigin”” from Debians “/etc/apache2/conf-enabled/security.conf” conifg file.
A smart workaround is to add “Header unset X-Frame-Options:” to the Apache site configuration file for Collabora.
It would be great if this could be added to the documentation.
