I installed collabora online office as described on the nextcloud side.
First, I tried to use nginx with several different configs I found here in the forum, second I installed apache as well and configured office.roessner-net.de on port 8443 there.
Here is my current apache config:
<IfDefine SSL>
<IfModule ssl_module>
<IfDefine XML2ENC>
LoadModule xml2enc_module modules/mod_xml2enc.so
</IfDefine>
Listen 8443
<VirtualHost 134.255.226.244:8443>
ServerName office.roessner-net.de
ErrorLog /var/log/apache2/ssl_error_log
<IfModule log_config_module>
TransferLog /var/log/apache2/ssl_access_log
</IfModule>
# SSL configuration, you may want to take the easy route instead and use Lets Encrypt!
SSLEngine on
SSLCertificateFile /etc/letsencrypt/live/office.roessner-net.de/cert.pem
SSLCertificateChainFile /etc/letsencrypt/live/office.roessner-net.de/chain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/office.roessner-net.de/privkey.pem
SSLProtocol all -SSLv2 -SSLv3
SSLCipherSuite ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS
SSLHonorCipherOrder on
# Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
# Container uses a unique non-signed certificate
SSLProxyEngine On
SSLProxyVerify None
SSLProxyCheckPeerCN Off
SSLProxyCheckPeerName Off
# keep the host
ProxyPreserveHost On
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of LibreOffice Online
ProxyPass /loleaflet https://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet https://127.0.0.1:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery https://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery https://127.0.0.1:9980/hosting/discovery
# Main websocket
ProxyPassMatch "/lool/(.*)/ws$" wss://127.0.0.1:9980/lool/$1/ws nocanon
# Admin Console websocket
ProxyPass /lool/adminws wss://127.0.0.1:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool https://127.0.0.1:9980/lool
ProxyPassReverse /lool https://127.0.0.1:9980/lool
</VirtualHost>
</IfModule>
</IfDefine>
# vim: ts=4 filetype=apache
My nextcloud installation runs under https://roessner-net.de/nextcloud. I started collabora like this:
#!/bin/bash
docker pull collabora/code
docker run -t -d \
-p 127.0.0.1:9980:9980 \
-e 'domain=roessner-net\\.de' \
--restart always \
--cap-add MKNOD \
--name collabora \
-e "username=..." -e "password=..." \
collabora/code
exit 0
When trying to open a odt document, the web user interface of collabora gets loaded and I see connecting. After a moment I receive an error that it could not load the document.
Running the docker container in foreground, I see these messages:
./collabora.sh
Using default tag: latest
latest: Pulling from collabora/code
Digest: sha256:7abe64fbc35fd83e23585ad430f56197323753a00b8f919b2dcd95066a513e32
Status: Image is up to date for collabora/code:latest
Generating RSA private key, 2048 bit long modulus
e is 65537 (0x10001)
Signature ok
subject=/C=DE/ST=BW/L=Stuttgart/O=Dummy Authority/CN=localhost
Getting CA Private Key
loolforkit version details: 2.0.4 - 2.0.4
wsd-00026-0029 12:47:55.799689 [ client_req_hdl ] WRN WOPI host did not pass optional access_token_ttl| wsd/FileServer.cpp:255
wsd-00026-0030 12:47:56.392413 [ client_ws_0003 ] WRN getNewChild: No available child. Sending spawn request to forkit and failing.| wsd/LOOLWSD.cpp:422
wsd-00026-0030 12:48:01.392975 [ client_ws_0003 ] WRN getNewChild: No available child. Sending spawn request to forkit and failing.| wsd/LOOLWSD.cpp:447
wsd-00026-0030 12:48:01.393144 [ client_ws_0003 ] WRN getNewChild: No available child. Sending spawn request to forkit and failing.| wsd/LOOLWSD.cpp:422
wsd-00026-0030 12:48:01.774287 [ client_ws_0003 ] ERR Error in client request handler: Connection refused| wsd/LOOLWSD.cpp:1038
office version details: { "ProductName": "Collabora Office", "ProductVersion": "5.1", "ProductExtension": ".10.21", "BuildId": "e91d2c2d59b035e40bdefac5fe06fb210180ed86" }
wsd-00026-0032 12:48:01.891153 [ client_ws_0005 ] ERR Error in client request handler: Connection refused| wsd/LOOLWSD.cpp:1038
wsd-00026-0031 12:48:01.893142 [ client_ws_0004 ] ERR Error in client request handler: Connection refused| wsd/LOOLWSD.cpp:1038
Unfortunately I have no idea, what these errors mean. Also searching here on the forum and with Google, I was not able to solve this problem.
This is my first-time usage for CODE.
I really thank you for any hint that you could give to me.
Thanks in advance
Christian
