Hey there
I bought a Raspberry Pi 3B+, downloaded the NextcloudPi-Image as a torrent from https://ownyourbits.com/downloads/NextCloudPi_RPi_03-09-19, flashed the image with etcher on a 64GB-miniSDHC, put a file ssh on the boot partition and launched the machine. At a first glance, the boot process shows no problems.
But …
When I try to activate the system (via Firefox and https://nextcloudpi.local:4443/activate/), I get the message
“NextCloudPi not yet initialized, trying again in a few seconds …”
Then nothing more happens.
The last lines from the boot.log are:
[ OK ] Started /etc/rc.local Compatibility.
Starting Terminate Plymouth Boot Screen…
Starting Hold until boot process finishes up…
I recognized, I am able to login via ssh and do a sudo ncp-config.
It shows, that it is Version 1.9.3.
Updating is impossible - the error “/usr/local/bin/ncp/TOOLS/nc-update.sh not found” appears.
What can I do?
Thank you for ideas!
Chris
