Hi Nextcloud community,
I’ve upgraded from 17.0 to 18.0.1.3 manually (copy data/ and config/config.php, ran “occ upgrade”.
Since then I can’t see any files on the Webgui: https://i.imgur.com/WixMyi6.png
What I have done so far:
- So I’ve ran “occ files:scan --all”, no success
- I’ve disabled all apps: https://i.imgur.com/m0u7bVM.png , no success
- restarted nginx as well as php fpm
- Then I’ve checked if all files belong to the correct User “$ find . ! -user www-data -print”, no success
- Then I took a look at the Browser: https://i.imgur.com/BxvKDv5.png
- So I figured that I must have messed up something on installation/upgrade
So I exploded the zipfile again, changed ownership, copied config/config.php as well as moving data/. Tried upgrading “$ sudo -u www-data php occ upgrade
Nextcloud is already latest version”
So that didn’t change anything and I am running out of Ideas.
I’ve uploaded the last 100 lines of the Log to: https://pastebin.pl/view/0614eb28
Could someone please point me what I’ve done wrong?
Server base OS: ubuntu 18.04, nignx 1.14.0, php 7.2.24
Thanks in advance.
Cheers,
Mike
