Hi there,
I’ve installed Nextcloud with Snappy packaging system following the instruction here:
The installation went successfully and Nextcloud is running up from the start, while it looks like the package is not updated automatically.
Would someone please let me know how to update that manually or to set it updated automatically?
Here is the log by executing snap info nextcloud
user@localhost:~$ snap info nextcloud
summary: Nextcloud Server - A safe home for all your data
publisher: Nextcloudâś“
license: unset
description: |
Where are your photos and documents? With Nextcloud you pick a server of
your choice, at home, in a data center or at a provider. And that is where
your files will be. Nextcloud runs on that server, protecting your data and
giving you access from your desktop or mobile devices. Through Nextcloud
you also access, sync and share your existing data on that FTP drive at
school, a Dropbox or a NAS you have at home.
commands:
- nextcloud.disable-https
- nextcloud.enable-https
- nextcloud.export
- nextcloud.import
- nextcloud.manual-install
- nextcloud.mysql-client
- nextcloud.mysqldump
- nextcloud.occ
services:
nextcloud.apache: simple, enabled, active
nextcloud.mdns-publisher: simple, enabled, active
nextcloud.mysql: simple, enabled, active
nextcloud.nextcloud-cron: simple, enabled, active
nextcloud.nextcloud-fixer: simple, enabled, inactive
nextcloud.php-fpm: simple, enabled, active
nextcloud.redis-server: simple, enabled, active
nextcloud.renew-certs: simple, enabled, active
snap-id: njObIbGQEaVx1H4nyWxchk1i8opy4h54
tracking: stable
refresh-date: 38 days ago, at 03:25 JST
channels:
stable: 15.0.7snap1 2019-04-10 (12753) 204MB -
candidate: ↑
beta: 15.0.7snap1+git6.630033d 2019-04-17 (12885) 205MB -
edge: master-2019-04-19 2019-04-19 (12912) 210MB -
16/stable: –
16/candidate: 16.0.0rc2snap1 2019-04-18 (12892) 210MB -
16/beta: ↑
16/edge: ↑
15/stable: 15.0.7snap1 2019-04-10 (12753) 204MB -
15/candidate: ↑
15/beta: ↑
15/edge: 15-2019-04-19 2019-04-19 (12917) 205MB -
14/stable: 14.0.7snap1 2019-02-22 (11748) 194MB -
14/candidate: ↑
14/beta: 14.0.7snap1+git4.c4636f0 2019-03-16 (12202) 202MB -
14/edge: 14-2019-04-19 2019-04-19 (12920) 203MB -
13/stable: 13.0.11snap1 2019-02-22 (11752) 188MB -
13/candidate: ↑
13/beta: 13.0.11snap1+git4.92e1309 2019-03-16 (12199) 193MB -
13/edge: 13-2019-04-11 2019-04-11 (12787) 194MB -
12/stable: 12.0.13snap1 2019-01-07 (10632) 206MB -
12/candidate: ↑
12/beta: ↑
12/edge: ↑
11/stable: 11.0.8snap1 2018-05-10 (6942) 202MB -
11/candidate: ↑
11/beta: ↑
11/edge: ↑
installed: 15.0.5snap1 (11891) 205MB devmode
It says it tracks stable
but the package remains 15.0.5snap1
, which should be 15.0.7snap1
Thanks in advance,
