- 31.0.2
Ubuntu 24.0
Apache 2.4
MySQL 8.0
- PHP version (e.g, 8.3):
php 8.3
Yes
today after automatic Update from Version 30
SNAP
No
WebAuthn doesn’t work anymore.
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
RequestException cURL error 60: SSL certificate problem: self signed certificate (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://server/extra-apps/richdocumentscode/proxy.php?req=/hosting/discovery
Failed to fetch discovery: cURL error 60: SSL certificate problem: self signed certificate (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://server/extra-apps/richdocumentscode/proxy.php?req=/hosting/discovery
Can you help me?
