I want to demonstrate NextCloud as a viable proof-of-concept for non-technical stakeholders. I am trying to install and deploy NextCloud as quickly and painlessly as possible; I installed via snap with an IP address (i.e. no domain name) and a self-signed certificate. I can’t access it through the browser.
Should I shutdown the snap deployment and deploy conventionally (i.e. install/configure each LAMP component and then install NextCloud) or is there something else I can do to tweak my snap deployment?
I have NextCloud running (I think). I was able to get the following output from snap:
$ sudo snap services
Service Startup Current
nextcloud.apache enabled active
nextcloud.mdns-publisher enabled active
nextcloud.mysql enabled active
nextcloud.nextcloud-cron enabled active
nextcloud.php-fpm enabled active
nextcloud.redis-server enabled active
nextcloud.renew-certs enabled active
@Reiner_Nippes: I’m running Ubuntu 18.04.1. I’m getting an error where the script, ./prepare_system.sh is trying to install pip. The pip installation script thinks the system has Python 3, but /usr/bin/python is Python 2. I’ve done some googling; I’ve installed Python 3 but that hasn’t changed the version of the above python runtime. What are some things I can do?
software-properties-common is already the newest version (0.96.24.32.6).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
+ PYTHON_BIN=/usr/bin/python
+ install_pip
+ sudo -H /usr/bin/python
+ curl https://bootstrap.pypa.io/get-pip.py
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1622k 100 1622k 0 0 7915k 0 --:--:-- --:--:-- --:--:-- 7877k
Traceback (most recent call last):
File "<stdin>", line 20890, in <module>
File "<stdin>", line 197, in main
File "<stdin>", line 82, in bootstrap
File "/tmp/tmpO_1u4F/pip.zip/pip/_internal/__init__.py", line 19, in <module>
File "/tmp/tmpO_1u4F/pip.zip/pip/_vendor/urllib3/__init__.py", line 8, in <module>
File "/tmp/tmpO_1u4F/pip.zip/pip/_vendor/urllib3/connectionpool.py", line 11, in <module>
File "/tmp/tmpO_1u4F/pip.zip/pip/_vendor/urllib3/exceptions.py", line 2, in <module>
File "/tmp/tmpO_1u4F/pip.zip/pip/_vendor/urllib3/packages/six.py", line 203, in load_module
File "/tmp/tmpO_1u4F/pip.zip/pip/_vendor/urllib3/packages/six.py", line 115, in _resolve
File "/tmp/tmpO_1u4F/pip.zip/pip/_vendor/urllib3/packages/six.py", line 82, in _import_module
ImportError: No module named httplib
I had to do a couple things for the installation script to work:
First I changed the path to PYTHON_BIN to /usr/bin/python3.
Then I installed sudo apt install python3-distutils.
I don’t know if that makes a difference to change the script. Also, you’ve got a number of minor typos. Do a search for ‘Sytem’ in your script.
Just FYI for anyone following this thread, I gave up and just did a traditional LAMP stack installation and configuration. It was actually more straight-forward for me because I understand those technologies versus trying to troubleshoot Snap or Docker.
I’m pretty sure it’s the server edition, since it was the default install from my VPS provider; it doesn’t make sense for them to install the desktop edition…
hmmm.
I tested the script on AWS EC2, DigitalOcean, Scaleway, VirtualBox Ubuntu 18.04.
So it’s hard for me to tell what’s missing in the Ubuntu distro of your provider. Sorry.
