whole day I try to move the data dir to some other place … no success
Using nginx with reverse proxy, nc installed with snap, ports changed to 1080/1443 … works fine.
Now I try to change the data directory.
Changing
'directory' => '/media/my/new/data',
and moving the data after stopping snap nextcloud doesn’t work.
Moving the data and using a symlink doesn’t work either.
I always end up with HTTP 502 or some internal error. Reloading nginx seems to make a difference … for a reason I do not understand.
I think my use case is not too uncommon, so maybe someone has got a solution?
- Wolfgang
