This seems to be a common problem, but none of the threads I’ve read have helped.
I’m running an Ubuntu Server 17.04 virtual machine in Proxmox on a Dell R710. Following a fresh install of the operating system, I ran apt-get update/upgrade and installed Nextcloud using Snap.
I can access the WebGUI no problem. I run into the “smbclient” is not installed problem.
I have installed smbclient and php-smbclient. Reading through the Nextcloud documentation, I feel strongly that these should be the only necessary steps.
I’m getting frustrated as I’ve read a lot of threads that seem to suggest 9 versions of the same package for 1 of 7 Linux distros. Or editing config files seemingly at random. Then poof! Some unexplained solution worked after trying 15 things and rebooting.
I’ve seen some references to PHP versions. I’m running 7 so I’m not sure if there could be a problem there.
Any help is greatly appreciated! I moved from FreeNAS to Proxmox. FreeNAS had easy WebDAV setup and it’s integral to my home server.
Thank you
I corrected the problem by restoring a backup prior to any configuration and installed Nextcloud without the Snap package. SMB is working fine now. Now on to my next problem…
I installed a clean Ubuntu server 18.0.1 . During this Ubuntu installation I selected Nextcloud. (it appears Ubuntu then uses the snap version).
- Nextcloud 13.0.5
- PHP 7.2.7
After installation I then did the following:
# sudo apt install smbclient
# sudo add-apt-repository universe
# sudo apt install php-smblient
# sudo reboot now
It still shows: ““smbclient” is not installed. Mounting of “SMB / CIFS”, “SMB / CIFS using OC login” is not possible. Please ask your system administrator to install it.”
What did I do wrong here? Given the instructions and the use of standard packages: shouldn’t this just work?
Oops, I did find this:
It is indeed a bug and it needs to be fixed. unfortunately it has been open for almost 2 years now…
Solution below worked for me.
apt -y install smbclient cifs-utils libsmbclient-dev php-dev make
pecl install smbclient
echo ‘extension=smbclient.so’ >> /etc/php/7.4/fpm/php.ini
systemct restart php7.4-fpm
Make sure you replace the PHP version number with your current PHP version. Tested and works in Nextcloud Version 20.
