Thanks for reporting issues back to Nextcloud!
Note: This is the **issu…e tracker of Nextcloud**, please do NOT use this to get answers to your questions or get help for fixing your installation. This is a place to report bugs to developers, after your server has been debugged. You can find help debugging your system on our home user forums: https://help.nextcloud.com or, if you use Nextcloud in a large organization, ask our engineers on https://portal.nextcloud.com. See also https://nextcloud.com/support for support options.
Nextcloud is an open source project backed by Nextcloud GmbH. Most of our volunteers are home users and thus primarily care about issues that affect home users. Our paid engineers prioritize issues of our customers. If you are neither a home user nor a customer, consider paying somebody to fix your issue, do it yourself or become a customer.
Guidelines for submitting issues:
* Please search the existing issues first, it's likely that your issue was already reported or even fixed.
- Go to https://github.com/nextcloud and type any word in the top search/command bar. You probably see something like "We couldn’t find any repositories matching ..." then click "Issues" in the left navigation.
- You can also filter by appending e. g. "state:open" to the search string.
- More info on search syntax within github: https://help.github.com/articles/searching-issues
* This repository https://github.com/nextcloud/server/issues is *only* for issues within the Nextcloud Server code. This also includes the apps: files, encryption, external storage, sharing, deleted files, versions, LDAP, and WebDAV Auth
* SECURITY: Report any potential security bug to us via our HackerOne page (https://hackerone.com/nextcloud) following our security policy (https://nextcloud.com/security/) instead of filing an issue in our bug tracker.
* The issues in other components should be reported in their respective repositories: You will find them in our GitHub Organization (https://github.com/nextcloud/)
* You can also use the Issue Template app to prefill most of the required information: https://apps.nextcloud.com/apps/issuetemplate
### How to use GitHub
* Please use the 👍 [reaction](https://blog.github.com/2016-03-10-add-reactions-to-pull-requests-issues-and-comments/) to show that you are affected by the same issue.
* Please don't comment if you have no relevant information to add. It's just extra noise for everyone subscribed to this issue.
* Subscribe to receive notifications on status change and new comments.
### Steps to reproduce
1. Add webdav external storage
2. Tries to open big file there (e.g. 800 MB) **or** Sync folder via client
3. See an error
4. Check the logs and see:
GuzzleHttp\Exception\ConnectException: cURL error 28: Operation timed out after 30000 milliseconds with 379564427 out of 838860800 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://magentacloud.de/remote.php/webdav/System/NewTea.avi
Seems it is related to #30262 and #29969 with #26071
5. Use Workaround as per https://github.com/nextcloud/server/issues/26071#issuecomment-901785979
6. See that Web UI is now opening, but with a huge delay (whole file being downloaded), but client sync does not work still.
### Expected behaviour
Do not download files (as per #30262) when folder simply opened, use cache instead.
Do not download files when properties only needed (last modification date, or size)
### Actual behaviour
External Storage could not be synchronized, even via Desktop Client it simply does not open and not synced any more.
All files downloaded to `/tmp` or RAM and causing timeout.
### Server configuration
**Operating system:** Ubuntu 20.04
**Web server:** Apache/2.4.51
**Database:** 10.3.32-MariaDB
**PHP version:** 7.4.26
**Nextcloud version:** 22.2.3.0
**Updated from an older Nextcloud/ownCloud or fresh install:** updated
**Where did you install Nextcloud from:** Official
**Signing status:**
<details>
<summary>Signing status</summary>
No errors have been found.
</details>
**List of activated apps:**
<details>
<summary>App list</summary>
- accessibility: 1.8.0
- activity: 2.15.0
- admin_audit: 1.12.0
- audioplayer: 3.2.2
- bruteforcesettings: 2.2.0
- calendar: 3.0.0
- camerarawpreviews: 0.7.15
- checksum: 1.1.2
- cloud_federation_api: 1.5.0
- comments: 1.12.0
- contacts: 4.0.6
- contactsinteraction: 1.3.0
- cospend: 1.4.3
- dashboard: 7.2.0
- data_request: 1.9.0
- dav: 1.19.0
- deck: 1.5.5
- drawio: 1.0.1
- external: 3.9.0
- extract: 1.3.2
- facerecognition: 0.8.5
- federatedfilesharing: 1.12.0
- files: 1.17.0
- files_automatedtagging: 1.12.0
- files_downloadactivity: 1.11.1
- files_external: 1.13.0
- files_mindmap: 0.0.25
- files_pdfviewer: 2.3.1
- files_retention: 1.11.1
- files_rightclick: 1.1.0
- files_sharing: 1.14.0
- files_trashbin: 1.12.0
- files_versions: 1.15.0
- files_videoplayer: 1.11.0
- firstrunwizard: 2.11.0
- forms: 2.4.0
- gpxedit: 0.0.14
- gpxpod: 4.3.0
- integration_github: 1.0.2
- integration_gitlab: 1.0.3
- keeweb: 0.6.8
- logreader: 2.7.0
- lookup_server_connector: 1.10.0
- mail: 1.11.0
- maps: 0.1.9
- nextcloud_announcements: 1.11.0
- notes: 4.2.0
- notifications: 2.10.1
- oauth2: 1.10.0
- ocdownloader: 1.7.12
- password_policy: 1.12.0
- phonetrack: 0.6.9
- photos: 1.4.0
- polls: 3.3.0
- previewgenerator: 3.3.0
- privacy: 1.6.0
- provisioning_api: 1.12.0
- recommendations: 1.1.0
- serverinfo: 1.12.0
- settings: 1.4.0
- sharebymail: 1.12.0
- side_menu: 2.0.1
- spreed: 12.1.2
- support: 1.5.0
- survey_client: 1.10.0
- systemtags: 1.12.0
- text: 3.3.0
- theming: 1.13.0
- twofactor_backupcodes: 1.11.0
- twofactor_totp: 6.1.0
- unsplash: 1.2.4
- updatenotification: 1.12.0
- user_status: 1.2.0
- video_converter: 1.0.3
- viewer: 1.6.0
- weather_status: 1.2.0
- workflowengine: 2.4.0
- circles
- encryption
- federation
- files_accesscontrol
- flowupload
- gpxmotion
- impersonate
- integration_jira
- radio
- recognize
- user_ldap
- weather
</details>
**Nextcloud configuration:**
<details>
<summary>Config report</summary>
"***REMOVED SENSITIVE VALUE***",
"overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
"dbtype": "mysql",
"version": "22.2.3.0",
"dbport": "",
"mysql.utf8mb4": true,
"filesystem_check_changes": 0,
"filelocking.enabled": true,
"redis": {
"port": 0,
"timeout": 1.5
"default_phone_region": "DE",
"mail_smtpmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"theme": "",
"logfile": "\/var\/nextcloud\/data\/nextcloud.log",
"loglevel": 1,
"trashbin_retention_obligation": "14, auto",
"versions_retention_obligation": "14, auto",
"data-fingerprint": "7be51475e95ea13b254cd880319d98ec",
"enable_previews": true,
"enabledPreviewProviders": [
"OC\\Preview\\PNG",
"OC\\Preview\\JPEG",
"OC\\Preview\\GIF",
"OC\\Preview\\BMP",
"OC\\Preview\\XBitmap",
"OC\\Preview\\Movie",
"OC\\Preview\\PDF",
"OC\\Preview\\MP3",
"OC\\Preview\\TXT",
"OC\\Preview\\MarkDown"
"preview_max_x": 1920,
"preview_max_y": 1080,
"jpeg_quality": 90,
"mail_smtpsecure": "tls",
"mail_smtpauth": 1,
"mail_smtpport": "587",
"twofactor_enforced": true,
"admin"
"has_rebuilt_cache": true,
"mail_sendmailmode": "smtp"
</details>
**Are you using external storage, if yes which one:** local/webdav
**Are you using encryption:** no
**Are you using an external user-backend, if yes which one:** no
### Logs
#### Nextcloud log (data/nextcloud.log)
<details>
<summary>Nextcloud log</summary>
{"reqId":"3bdICeP14G6vPYqfCKqQ","level":3,"time":"2021-12-15T09:30:33+00:00","remoteAddr":"","user":"--","app":"files","method":"","url":"--","message":"cURL error 28: Operation timed out after 30000 milliseconds with 379564427 out of 838860800 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://magentacloud.de/remote.php/webdav/System/NewTea.avi","userAgent":"--","version":"22.2.3.0","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Operation timed out after 30000 milliseconds with 379564427 out of 838860800 bytes received (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://magentacloud.de/remote.php/webdav/System/NewTea.avi","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":158,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":110,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::"},{"file":"/var/www/nextcloud/lib/private/Http/Client/DnsPinMiddleware.php","line":146,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":63,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":331,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":168,"function":"transfer","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Client.php","line":187,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Http/Client/Client.php","line":223,"function":"request","class":"GuzzleHttp\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/DAV.php","line":356,"function":"get","class":"OC\\Http\\Client\\Client","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/LocalTempFileTrait.php","line":65,"function":"fopen","class":"OC\\Files\\Storage\\DAV","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/LocalTempFileTrait.php","line":48,"function":"toTmpFile","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Common.php","line":269,"function":"getCachedFile","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":367,"function":"getLocalFile","class":"OC\\Files\\Storage\\Common","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php","line":374,"function":"getLocalFile","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php","line":367,"function":"getLocalFile","class":"OC\\Files\\Storage\\Wrapper\\Availability","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Check/FileMimeType.php","line":131,"function":"getLocalFile","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Check/FileMimeType.php","line":109,"function":"getActualValue","class":"OCA\\WorkflowEngine\\Check\\FileMimeType","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Service/RuleMatcher.php","line":245,"function":"executeCheck","class":"OCA\\WorkflowEngine\\Check\\FileMimeType","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Service/RuleMatcher.php","line":180,"function":"check","class":"OCA\\WorkflowEngine\\Service\\RuleMatcher","type":"->"},{"file":"/var/www/nextcloud/apps/workflowengine/lib/Service/RuleMatcher.php","line":128,"function":"getMatchingOperations","class":"OCA\\WorkflowEngine\\Service\\RuleMatcher","type":"->"},{"file":"/var/www/nextcloud/apps/files_automatedtagging/lib/Operation.php","line":95,"function":"getFlows","class":"OCA\\WorkflowEngine\\Service\\RuleMatcher","type":"->"},{"file":"/var/www/nextcloud/apps/files_automatedtagging/lib/Listener/CacheListener.php","line":43,"function":"checkOperations","class":"OCA\\FilesAutomatedTagging\\Operation","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/ServiceEventListener.php","line":75,"function":"handle","class":"OCA\\FilesAutomatedTagging\\Listener\\CacheListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":251,"function":"__invoke","class":"OC\\EventDispatcher\\ServiceEventListener","type":"->"},{"file":"/var/www/nextcloud/3rdparty/symfony/event-dispatcher/EventDispatcher.php","line":73,"function":"callListeners","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":88,"function":"dispatch","class":"Symfony\\Component\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/EventDispatcher/EventDispatcher.php","line":100,"function":"dispatch","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Cache.php","line":324,"function":"dispatchTyped","class":"OC\\EventDispatcher\\EventDispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":294,"function":"insert","class":"OC\\Files\\Cache\\Cache","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":224,"function":"addToCache","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":427,"function":"scanFile","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":388,"function":"handleChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":340,"function":"scanChildren","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":510,"function":"scan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":521,"function":"OC\\Files\\Cache\\{closure}","class":"OC\\Files\\Cache\\Scanner","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/Files/Cache/Scanner.php","line":509,"function":"runBackgroundScanJob","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/lib/private/Files/Utils/Scanner.php","line":185,"function":"backgroundScan","class":"OC\\Files\\Cache\\Scanner","type":"->"},{"file":"/var/www/nextcloud/apps/files/lib/BackgroundJob/ScanFiles.php","line":89,"function":"backgroundScan","class":"OC\\Files\\Utils\\Scanner","type":"->"},{"file":"/var/www/nextcloud/apps/files/lib/BackgroundJob/ScanFiles.php","line":125,"function":"runScanner","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/Job.php","line":51,"function":"run","class":"OCA\\Files\\BackgroundJob\\ScanFiles","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/TimedJob.php","line":58,"function":"execute","class":"OC\\BackgroundJob\\Job","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":127,"function":"execute","class":"OC\\BackgroundJob\\TimedJob","type":"->"}],"File":"/var/www/nextcloud/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":210,"CustomMessage":"--"},"id":"61b9f1e0b44fa"}
</details>
#### Nextcloud Desktop Client log
<details>
<summary>Nextcloud Client log</summary>
||MagentaCloud|2|2|1638616226|_invalid_|0|10006743xxxxxxxxxxx|4||0|0|0||
#=#=#=# Syncrun finished 2021-12-15T13:59:38Z (last step: 157 msec, total: 2134 msec)
#=#=#=# Syncrun started 2021-12-15T13:59:40Z
#=#=#=#=# Propagation starts 2021-12-15T14:00:24Z (last step: 43733 msec, total: 43733 msec)
#=#=#=# Syncrun finished 2021-12-15T14:00:24Z (last step: 24 msec, total: 43757 msec)
#=#=#=# Syncrun started 2021-12-15T14:01:03Z
#=#=#=#=# Propagation starts 2021-12-15T14:01:03Z (last step: 371 msec, total: 371 msec)
||MagentaCloud|8|2|1638616226|61ab4ca2b0b9c|0|10006743xxxxxxxxxxx|4||0|0|0||
#=#=#=# Syncrun finished 2021-12-15T14:01:03Z (last step: 28 msec, total: 399 msec)
</details>
