I am sorry, but I am not tech savy even on linux commands
I had help to install my nextcloud server with redis… and it has worked flawless but it works on AJAX
is there any easy workaround to put it to work
What I needed was to get selected feeds delivered to groups according to the importance for them
content groups -> blogs and media websites
web development -> technical sites
etc
I just don’t want to break my nextcloud that my friend jason got it work like a Ferrari on a Mini VPS
Thx
tflidd
September 6, 2018, 9:10am
2
Is there a reason that cronjobs are not running or do you just need help to set them up?
I dunno the reason why maybe it wasn’t setup because he saw no need
and the VPS is just 1 Gb.
If you ask me if I need help setting them up, I do
i am zero in linux command linne unless it comes in steps by steps and errors show up
thx for your reply tflidd
tflidd
September 7, 2018, 11:54am
4
you can try to run it once manually from command line and see if it breaks:
sudo -u www-data php -f /path/to/nextcloud/cron.php
Tried it and
Could not open input file: /path/to/nextcloud/cron.php
did find cron.php file and it is located at
/var/www/html/nextcloud/core/Command/Background/Cron.php
/var/www/html/nextcloud/cron.php
I am sure this must be easy… but for me sorry
tried correcting path and didn’t worked either… any ideas… I do need to learn linux asap
TIA
tflidd
September 8, 2018, 5:42pm
6
I couldn’t know the path you are using, it should be the second script your found. It should normally show errors if it does not work.
@tflidd and should the command be any different? I am sorry to ask you but I really do not master it.
you said for me to run
it replied
Since it may be located in another place
should I change the command?
Thank you so much, for being a dummy in this
tflidd
September 9, 2018, 5:20pm
8
Please use this path. /path/to..
was only used as a place holder because the actual path can be different in each system.
Got the path to /cron.php and ran it… took a while and terminal showed no errors
Now that I got to my nextcloud instance it says
Background jobs
Last job execution ran 3 hours ago. Something seems wrong.
I was so happy to see feed loading… but ain’t working
tflidd
September 10, 2018, 8:13pm
10
then you can add this command to your cron jobs and it will be run on a regular basis. Check some documentation of your distribution on how to add a command and to run it every 15 minutes.
I am running an Ubuntu 16.04 LTS
checked docs on it… but my friend tflidd you (nextcloud) did not make it easy, moreover, if it is what you recommend.
To check if cron.pho is running well I did the test
https://mydomain/cron.php
and it said success
I used nano to open crontab and added (right after the certbot renew)
*/15 * * * * php -f /var/www/html/nextcloud/cron.php
nope… came out wrong again
I do not quite feel like paying those sites to get a simple cronjob command
Also went looking at nextcloud documentation
can you help me with the right command in case you know
TIA
Sorry for bothering you for so long on this
tflidd
September 13, 2018, 8:34am
12
I thought you have a VPS with full admin rights?
With such detailed error description, don’t expect anybody to help you.
Horton
September 17, 2018, 2:18pm
13
If you is having problem with cron job settings, using online cron job like https://www.easycron.com as an alternative is a good idea.
MeiRos
September 17, 2018, 2:56pm
14
I did it like this.
crontab -e -u nginx
Nginx is my webserver user. With nginx it’s propably nginx. Apache and it’s www-data. Check the owner of your Nextcloud files.
After the command is run, do the same like you did with nano. If it’s still not working, add full path to your php. Like /my/php/ishere/php - f …
If still not working, read all your logs.
Thanks for your help got it running, by going to a few dozens of pages but now it works
*/15 * * * * sudo -u www-data php -f /var/www/html/nextcloud/cron.php
This solved it, working like a swiss clock
Thank you to all
