example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.2.0.2
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.41
PHP version (eg, 7.4): 7.4
I am having problems with my Upload Speed, over the Webinterface. (30 MB/s)
Download is at about 60 MB/s and so is the Upload over SFTP (WinSCP)
N
Everytime I Upload
'passwordsalt' => 'removed',
'secret' => 'removed',
0 => 'localhost',
1 => 'removed',
2 => 'removed,
3 => 'removed',
'datadirectory' => '/mnt/ncdata',
'dbtype' => 'pgsql',
'version' => '22.2.0.2',
'overwrite.cli.url' => 'removed',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'removed',
'dbpassword' => 'removed',
'instanceid' => 'removed',
'log_type' => 'file',
'loglevel' => '2',
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'mail_smtpmode' => 'smtp',
'remember_login_cookie_lifetime' => '1800',
'log_rotate_size' => '10485760',
'trashbin_retention_obligation' => 'auto, 60',
'versions_retention_obligation' => 'auto, 180',
'redis' =>
'port' => 0,
'timeout' => 0.5,
'dbindex' => 0,
'password' => 'removed',
'default_phone_region' => 'ch',
'logtimezone' => 'Europe/Amsterdam',
'auth.webauthn.enabled' => false,
'mail_smtpsecure' => 'ssl',
'mail_domain' => 'removed',
'mail_smtpauth' => 1,
'mail_smtphost' => 'removed',
'mail_smtpport' => '465',
'mail_smtpname' => 'removed',
'mail_smtppassword' => 'removed',
'skeletondirectory' => '',
