Slow Upload Speed - How Do I Tweak It?
Hi
I experience slow upload speed when uploading large files from a browser. The speed is very slow when http2 is enabled - it is better with just http1.1 - but could still be better. Is there some tweaking I could to do to improve the speed?
Nextcloud version (eg, 20.0.5): 24.0.1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.4 LTS
Apache or nginx version: Apache 2.4.41
PHP version (eg, 7.4): PHP 8.1.6
https://pastebin.com/TQQwHGdc
  'passwordsalt' => 'REDACTED',
  'secret' => 'REDACTED',
    0 => 'REDACTED',
    1 => 'REDACTED',
  'datadirectory' => '/home/nextclouddata',
  'version' => '24.0.1.1',
  'overwrite.cli.url' => 'REDACTED',
  'dbname' => 'nextcloud',
  'dbhost' => 'localhost',
  'dbuser' => 'nextcloud',
  'dbpassword' => 'REDACTED',
  'instanceid' => 'REDACTED',
  'loglevel' => 1,
  'mail_smtpmode' => 'smtp',
  'mail_smtpsecure' => 'tls',
  'mail_domain' => 'REDACTED',
  'mail_from_address' => 'REDACTED',
  'mail_smtpauth' => 1,
  'mail_smtphost' => 'REDACTED',
  'mail_smtpport' => '587',
  'mail_smtpname' => 'REDACTED',
  'mail_smtppassword' => 'REDACTED',
  'theme' => '',
  'default_language' => 'da',
  'default_locale' => 'da_DK',
  'default_phone_region' => 'DK',
  'memcache.local' => '\OC\Memcache\Redis',
  'memcache.locking' => '\OC\Memcache\Redis',
  'memcache.distributed' => '\OC\Memcache\Redis',
  'redis' => [
        'host' => 'localhost', // can also be a unix domain socket: '/tmp/redis.sock'
        'port' => 6379,
        'timeout' => 0.0,
        'read_timeout' => 0.0,
        'user' =>  '', // Optional, if not defined no password will be used.
        'password' => '', // Optional, if not defined no password will be used.
        'dbindex' => 0, // Optional, if undefined SELECT will not run and will use Redis Server's default DB Index.
Apache error log (notice installed Redis - so some of the errors are fixed) https://pastebin.com/3QFUwk35
JSON: External Monitoring:
https://pastebin.com/PdqC8u5N
For nginx, they added some hints in the documentation recently. Perhaps, you find a similar parameter for apache:
And if you speak about performances, it always good to specify some numbers. Recently someone complained about speed and was (for some parts at least) limited by the network connection speed (Improving the speed of my Nextcloud instance - #6 by bb77).
