My Nextcloud Instance uploads with roughly the same speed as sftp which is around 500kbps - 2mbps. That is obviously very slow! I already browsed all the other threads for that topic and most of them were just fixed by removing http2, but not for me :(.
I've already confirmed that it is not a problem with my internet as i asked a friend to try it and he got the same speed (his connection was much better than mine).
Nextcloud version (eg, 20.0.5): 22.1.1
Operating system and version (eg, Ubuntu 20.04): Debian 10
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.2
PHP version (eg, 7.4): 7.3
- Upload a decently sized file to nextcloud.
None
'instanceid' => 'CENSORED',
'passwordsalt' => 'CENSORED',
'secret' => 'CENSORED',
0 => 'CENSORED',
'datadirectory' => '/opt/nextcloud/data',
'version' => '22.1.1.2',
'overwrite.cli.url' => 'https://cloud.mydomain.net',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'nc_user',
'dbpassword' => 'CENSORED',
'redis' =>
'host' => '127.0.0.1',
'port' => 6379,
'skeletondirectory' => '/home/tueem/default-files',
'theme' => '',
'loglevel' => 2,
'app_install_overwrite' =>
0 => 'admin_notifications',
1 => 'announcementcenter',
'mail_from_address' => 'support',
'mail_smtpmode' => 'smtp',
'mail_domain' => 'CENSORED',
'mail_smtphost' => 'CENSORED',
'mail_smtpport' => '25',
'mail_smtpauth' => 1,
'mail_smtpname' => 'CENSORED',
'mail_smtppassword' => 'CENSORED',
'mail_smtptimeout' => 30,
None but here is my Nginx config:
upstream php-handler {
# server 127.0.0.1:9000;
server unix:/var/run/php/php7.3-fpm.sock;
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name CENSORED;
# Use Mozilla's guidelines for SSL/TLS settings
# https://mozilla.github.io/server-side-tls/ssl-config-generator/
ssl_certificate /etc/ssl/certificate.crt;
ssl_certificate_key /etc/ssl/private.key;
# HSTS settings
# could take several months.
add_header Strict-Transport-Security "max-age=15552000; preload;" always;
# set max upload size
client_max_body_size 6024M;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
# Pagespeed is not supported by Nextcloud, so if your server is built
# with the `ngx_pagespeed` module, uncomment this line to disable it.
#pagespeed off;
# HTTP response headers borrowed from Nextcloud `.htaccess`
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
# Remove X-Powered-By, which is an information leak
root /opt/nextcloud;
# Specify how to handle directories -- specifying `/index.php$request_uri`
# here as the fallback means that Nginx always exhibits the desired behaviour
# when a client requests a path that corresponds to a directory that exists
# on the server. In particular, if that directory contains an index.php file,
# that file is correctly served; if it doesn't, then the request is passed to
# the front-end controller. This consistent behaviour means that we don't need
# to specify custom rules for certain paths (e.g. images and other assets,
# `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
# `try_files $uri $uri/ /index.php$request_uri`
# always provides the desired behaviour.
index index.php index.html /index.php$request_uri;
# Rule borrowed from `.htaccess` to handle Microsoft DAV clients
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
# Make a regex exception for `/.well-known` so that clients can still
# access it despite the existence of the regex rule
# `location ~ /(\.|autotest|...)` which would otherwise handle requests
# for `/.well-known`.
location ^~ /.well-known {
# The rules in this block are an adaptation of the rules
# in `.htaccess` that concern `/.well-known`.
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }
# Let Nextcloud's API for `/.well-known` URIs handle all other
# requests by passing them to the front-end controller.
return 301 /index.php$request_uri;
# Rules borrowed from `.htaccess` to hide certain paths from clients
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; }
# Ensure this block, which passes PHP files to the PHP process, is above the blocks
# which handle static assets (as seen below). If this block is not declared first,
# then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
# to the URI, resulting in a HTTP 500 error response.
location ~ \.php(?:$|/) {
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ \.(?:css|js|svg|gif)$ {
expires 6M; # Cache-Control policy borrowed from `.htaccess`
access_log off; # Optional: Don't log access to assets
location ~ \.woff2?$ {
expires 7d; # Cache-Control policy borrowed from `.htaccess`
location /remote {
return 301 /remote.php$request_uri;
location / {
try_files $uri $uri/ /index.php$request_uri;
