Slow upload and disconnects for ldap users
hi
I have a nextcloud server connected to active directory. Upload speed for ldap users is around 40 mbps while local users have upload speed of more than 100 mbps from the same workstation. Also when uploading large files, ldap users get disconnected and logout with error (included in this post) after around 5 to 6 minutes.
I have reinstalled the system on a new server (old server was on centos 7 and the new one has centos 9) and the problem exists.
please help
    • 23.0.12
    • centos 9
    • apache 2.4.62
    • replace me
    • 8.0
    • Yes
    • Bare Metal/
slow upload speed for ldap users
frequent disconnect (logout) when uploading large files for ldap users
{"reqId":"Z-FSy-Uslt8WJsCEwWcc1AAAABA","level":0,"time":"March 24, 2025 13:40:43","remoteAddr":"192.168.1.10","user":"--","app":"webdav","method":"PUT","url":"/remote.php/dav/uploads/user/web-file-upload-bfc7da4e3ff4d13bd85b93d8b29b4419-1742819823080/1635778560","message":"Cannot authenticate over ajax calls","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/111.0","version":"23.0.12.2","exception":{"Exception":"Sabre\\DAV\\Exception\\NotAuthenticated","Message":"Cannot authenticate over ajax calls","Code":0,"Trace":[{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":154,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":182,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":137,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["beforeMethod:PUT",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":339,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":170,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","Line":249,"CustomMessage":"--"}}
{"reqId":"Z-FSy-Uslt8WJsCEwWcc1QAAAAw","level":0,"time":"March 24, 2025 13:40:43","remoteAddr":"192.168.1.10","user":"--","app":"webdav","method":"DELETE","url":"/remote.php/dav/uploads/user/web-file-upload-bfc7da4e3ff4d13bd85b93d8b29b4419-1742819823080","message":"Cannot authenticate over ajax calls","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/111.0","version":"23.0.12.2","exception":{"Exception":"Sabre\\DAV\\Exception\\NotAuthenticated","Message":"Cannot authenticate over ajax calls","Code":0,"Trace":[{"file":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","line":154,"function":"auth","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":182,"function":"check","class":"OCA\\DAV\\Connector\\Sabre\\Auth","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php","line":137,"function":"check","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"beforeMethod","class":"Sabre\\DAV\\Auth\\Plugin","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":456,"function":"emit","class":"Sabre\\DAV\\Server","type":"->","args":["beforeMethod:DELETE",[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->","args":[{"__class__":"Sabre\\HTTP\\Request"},{"__class__":"Sabre\\HTTP\\Response"}]},{"file":"/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/lib/Server.php","line":339,"function":"exec","class":"Sabre\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->","args":[]},{"file":"/var/www/html/remote.php","line":170,"args":["/var/www/html/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php","Line":249,"CustomMessage":"--"}}
        "dbtype": "mysql",
        "forcessl": false,
        "blacklisted_files": [
            ".htaccess"
        "overwritehost": "",
        "overwritewebroot": "",
        "theme": "",
        "default_language": "en_US",
        "3rdpartyroot": "",
        "3rdpartyurl": "",
        "defaultapp": "files",
        "knowledgebaseenabled": true,
        "appstoreenabled": true,
        "mail_smtpdebug": false,
        "mail_smtpmode": "smtp",
        "mail_smtpport": "25",
        "mail_smtptimeout": 10,
        "mail_smtpauthtype": "LOGIN",
        "redis": {
            "port": 0
        "trashbin_retention_obligation": "30, auto",
        "allow_user_to_change_display_name": false,
        "appcodechecker": true,
        "updatechecker": true,
        "has_internet_connection": true,
        "check_for_working_webdav": true,
        "check_for_working_htaccess": true,
        "log_type": "owncloud",
        "logfile": "\/var\/log\/nextcloud.log",
        "loglevel": 0,
        "logdateformat": "F d, Y H:i:s",
        "logtimezone": "Europe\/Berlin",
        "log_query": false,
        "cron_log": true,
        "log_rotate_size": false,
        "remember_login_cookie_lifetime": 1296000,
        "session_lifetime": 86400,
        "session_keepalive": true,
        "session_relaxed_expiry": true,
        "auto_logout": false,
        "custom_csp_policy": "default-src 'self'; script-src 'self' 'unsafe-eval'; style-src 'self' 'unsafe-inline'; frame-src *; img-src *; font-src 'self' data:; media-src *",
        "xframe_restriction": true,
        "apps_paths": [
                "url": "\/apps",
                "writable": true
        "customclient_desktop": "",
        "customclient_android": "",
        "customclient_ios": "",
        "enable_previews": true,
        "preview_max_scale_factor": 10,
        "preview_libreoffice_path": "\/usr\/bin\/libreoffice",
        "preview_office_cl_parameters": "",
        "enable_avatars": true,
        "openssl": [],
        "cipher": "AES-256-CFB",
        "singleuser": false,
        "asset-pipeline.enabled": false,
        "mount_file": "",
        "cache_path": "",
        "quota_include_external_storage": false,
        "filesystem_check_changes": 1,
        "filesystem_cache_readonly": false,
        "share_folder": "\/",
        "version": "23.0.12.2",
        "appstore.experimental.enabled": true,
        "cas_dir": "\/usr\/share\/pear",
        "ldapIgnoreNamingRules": false,
        "debug": false,
        "login.alternatives": [],
        "ldapProviderFactory": "\\OCA\\User_LDAP\\LDAPProviderFactory",
        "twofactor_enforced": "false",
        "twofactor_enforced_groups": [],
        "mail_sendmailmode": "smtp"
  • accessibility: 1.9.0
  • admin_audit: 1.13.0
  • cloud_federation_api: 1.6.0
  • comments: 1.13.0
  • contacts: 4.2.5
  • contactsinteraction: 1.4.0
  • dashboard: 7.3.0
  • dav: 1.21.0
  • federatedfilesharing: 1.13.0
  • federation: 1.13.0
  • files: 1.18.0
  • files_external: 1.15.0
  • files_pdfviewer: 2.4.0
  • files_rightclick: 1.2.0
  • files_sharing: 1.15.0
  • files_trashbin: 1.13.0
  • files_versions: 1.16.0
  • files_videoplayer: 1.12.0
  • firstrunwizard: 2.12.0
  • group_default_quota: 0.1.5
  • groupfolders: 11.1.6
  • groupquota: 0.1.9
  • logreader: 2.8.0
  • lookup_server_connector: 1.11.0
  • nextcloud_announcements: 1.12.0
  • notifications: 2.11.2
  • oauth2: 1.11.0
  • password_policy: 1.13.0
  • photos: 1.5.0
  • privacy: 1.7.0
  • provisioning_api: 1.13.0
  • serverinfo: 1.13.0
  • settings: 1.5.0
  • sharebymail: 1.13.0
  • support: 1.6.0
  • systemtags: 1.13.0
  • text: 3.4.1
  • theming: 1.14.0
  • twofactor_backupcodes: 1.12.0
  • updatenotification: 1.13.0
  • user_ldap: 1.13.1
  • user_status: 1.3.1
  • viewer: 1.7.0
  • weather_status: 1.3.0
  • workflowengine: 2.5.0
  • activity: 2.2.1
  • bruteforcesettings: 2.4.0
  • circles: 23.1.2
  • encryption
  • limit_login_to_ip: 3.1.0
  • oidc_login: 2.6.0
  • recommendations: 0.4.0
  • survey_client: 1.10.0
