Nextcloud version (eg, 12.0.2): 15.0.4
Operating system and version (eg, Ubuntu 17.04): Ubuntu 18.04.2 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.29
PHP version (eg, 7.1): 7.2
mySQL version: 5.7.25-0
The loading of eg pictures takes a long time. Every time I switch to a folder I’ve been in, the pictures are reloaded over and over again. I can only view photos when the thumbnails are fully loaded. With a few thousand pictures something like that is quite annoying. It does not matter if it’s internal or external. Whether web interface or Android app. The data are on a Buffalo TeraStation HS-DHTGL / R5. The data is retrieved directly from Nextclud at the NAS. Internally, everything is connected with gigabit.
My Nextcloud is installed natively. There are eg 8GB RAM and a 250GB Samsung SSD available.
What can be done to avoid synchonisation over and over again? php-apcu is installed and opcache is configured.
'instanceid' => '---',
'passwordsalt' => '---',
'secret' => '---',
0 => 'xxx.xxx.x.x',
1 => 'xx.xxxxxx.at',
'version' => '15.0.4.0',
'overwrite.cli.url' => 'http://xxx.xxx.x.x',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '---',
'dbpassword' => '---',
'filelocking.enabled' => false,
Content opcache.ini:
zend_extension=opcache.so
opcache.enable=1
opcache.enable_cli=1
opcache.interned_strings_buffer=8
opcache.max_accelerated_files=10000
opcache.memory_consumption=128
opcache.save_comments=1
opcache.revalidate_freq=1
