Nextcloud version (eg, 20.0.5): NC 21.0.1 running inside linuxserver-nextcloud docker container
Not including any logs as it doesn’t generate any, it is a minor cosmetic issue only someone with too much time on their hands such as myself would notice.
Since probably NC20 (I don’t really look at the slogan that often, but I recall seeing it looking alright about when 20 was latest stable.) the slogan doesn’t display right. Now the text is cut off from top like so on Windows:
and even few pixels more cut off on Linux:
Moreover in the theming settings, the apostrophes in the slogan get converted to the html codes like so:
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
pics are from:
Win x64 physical machine
Linux x64 vm
both using latest Vivaldi x64 stable
Any advice welcome, thanks!
