When adding a skeleton dir inside your custom theme folder, the files inside won’t be copied to new users.
Is this a bug or is this not implemented?
Nextcloud Ver: 11.0.1
Have you seen:
The configuration option
skeletondirectoryavailable in your config.php (See Config.php Parameters) allows you to configure the directory where the skeleton files are located. These files will be copied to the data directory of new users. Leave empty to not copy any skeleton files.
