Hi everyone,
I just got my nextcloud running with collabora based on nginx. At this point: Thanks to all people posting in this forum which helped me a lot to got it running!
Now I have a question concerning the security/meaningfulness of my setup because I’m using the same certificate for nextcloud and collabora.
nginx config:
upstream php-handler {
server unix:/run/php-fpm/php-fpm.sock;
server {
listen 80;
server_name myNextCloudDomain;
# enforce https
return 301 https://$server_name$request_uri;
# Redirect non-https traffic to https
# if ($scheme != "https") {
# return 301 https://$host$request_uri;
# } # managed by Certbot
server {
listen 443 ssl http2;
ssl_certificate /etc/letsencrypt/live/myNextCloudDomain-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/myNextCloudDomain-0001/privkey.pem; # managed by Certbot
# Before enabling Strict-Transport-Security headers please read into this
# topic first.
# add_header Strict-Transport-Security "max-age=15768000;
# includeSubDomains; preload;";
#add_header X-Frame-Options "SAMEORIGIN";
add_header X-Robots-Tag none;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
root pathToMyNextcloudData;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
#rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
#rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json
# last;
location ~ /.well-known/acme-challenge {
allow all;
# set max upload size
client_max_body_size 512M;
fastcgi_buffers 64 4K;
# Disable gzip to avoid the removal of the ETag header
gzip off;
#pagespeed off;
error_page 403 /core/templates/403.php;
error_page 404 /core/templates/404.php;
location / {
rewrite ^ /index.php$uri;
deny all;
deny all;
location ~ ^/(?:index|remote|public|cron|core/ajax/update|status|ocs/v[12]|updater/.+|ocs-provider/.+|core/templates/40[34])\.php(?:$|/) {
include fastcgi_params;
fastcgi_split_path_info ^(.+\.php)(/.*)$;
fastcgi_param HTTPS on;
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ ^/(?:updater|ocs-provider)(?:$|/) {
try_files $uri/ =404;
index index.php;
# Adding the cache control header for js and css files
location ~* \.(?:css|js)$ {
try_files $uri /index.php$uri$is_args$args;
add_header Cache-Control "public, max-age=7200";
# Add headers to serve security related headers (It is intended to
# have those duplicated to the ones above)
# this topic first.
access_log off;
location ~* \.(?:svg|gif|png|html|ttf|woff|ico|jpg|jpeg)$ {
# Optional: Don't log access to other assets
access_log off;
server {
listen 9981 ssl;
# static files
location ^~ /loleaflet {
proxy_pass https://localhost:9980;
proxy_set_header Host $http_host;
# WOPI discovery URL
location ^~ /hosting/discovery {
# main websocket
location ~ ^/lool/(.*)/ws$ {
proxy_set_header Connection "Upgrade";
proxy_read_timeout 36000s;
# download, presentation and image upload
location ~ ^/lool {
# Admin Console websocket
location ^~ /lool/adminws {
In the admin section of nextcloud I’ve put the following into the field Collabora Online Server: https://myNextCloudDomain:9981
Sumup:
With this setup my nextcloud sends collabora related request to port 9981 and nginx redirects them to port 9980 where the docker image is listening. With this I can use the same domain and cert for nextcloud and collabora.
It works but is it a good practice? And is it critical to open port 9981 at my router (necessary to get it running)?
Thanks in advance!
