I use two Nextcloud servers, based on Debian 10 and apache 2.4 (all Debian 10 original pack).
On Nextcloud 18.0.2 I use only LDAP users and groups.
The Nextcloud servers (federated) works very well, but…
if I try to share a folder to an ldap group where I’am NOT present, sharing seems to works well, but is not visible to other users.
If I try to share a folder to an ldap user (on the same or another group) works fine.
If I try to share a folder to an ldap group where I’am present, works fine.
The setting “limit the users to share with users in the same group” is DISABLED.
Example:
I’m admin, if I share a directory to an LDAP group, the share is not visible (but seems ok: shared).
The same problem persist on two different server (same version 18.0.2, same app version).
I dont’use Group Folders app, if Luca (group A) create a new folder and try to share it with a group different from his… Tony (group B) does not display the shared directory…
If Luca try to share directly to Tony, works fine…
