Well wasn’t that the info you required, version, etc. The web server version : Apache 7.1.33
OCP\Files\NotPermittedException: Could not create path
/home/stoneufl/public_html/portal/lib/private/Files/SimpleFS/SimpleFolder.php - line 83:
OC\Files\Node\Folder->newFile(“6a15-4d36-settings-admin.css”)
/home/stoneufl/public_html/portal/lib/private/Template/SCSSCacher.php - line 311:
OC\Files\SimpleFS\SimpleFolder->newFile(“6a15-4d36-settings-admin.css”)
/home/stoneufl/public_html/portal/lib/private/Template/SCSSCacher.php - line 181:
OC\Template\SCSSCacher->cache("/home/stone … s", “6a15-4d36-settings-admin.css”, “settings-admin.scss”, OC\Files\Sim … {}, “/apps/feder … s”)
/home/stoneufl/public_html/portal/lib/private/Template/CSSResourceLocator.php - line 109:
OC\Template\SCSSCacher->process("/home/stone … g", “css/settings-admin.scss”, “federatedfilesharing”)
/home/stoneufl/public_html/portal/lib/private/Template/CSSResourceLocator.php - line 84:
OC\Template\CSSResourceLocator->cacheAndAppendScssIfExist("/home/stone … g", “css/settings-admin.scss”, “federatedfilesharing”)
/home/stoneufl/public_html/portal/lib/private/Template/ResourceLocator.php - line 78:
OC\Template\CSSResourceLocator->doFind(“css/settings-admin”)
/home/stoneufl/public_html/portal/lib/private/TemplateLayout.php - line 305:
OC\Template\ResourceLocator->find([ "css/serve … "])
/home/stoneufl/public_html/portal/lib/private/TemplateLayout.php - line 210:
OC\TemplateLayout::findStylesheetFiles([ "css/serve … "])
/home/stoneufl/public_html/portal/lib/private/legacy/template.php - line 183:
OC\TemplateLayout->__construct(“user”, “settings”)
/home/stoneufl/public_html/portal/lib/public/AppFramework/Http/TemplateResponse.php - line 165:
OC_Template->fetchPage({ forms: { p … "})
/home/stoneufl/public_html/portal/lib/private/AppFramework/Http/Dispatcher.php - line 123:
OCP\AppFramework\Http\TemplateResponse->render()
/home/stoneufl/public_html/portal/lib/private/AppFramework/App.php - line 126:
OC\AppFramework\Http\Dispatcher->dispatch(OC\Settings\ … {}, “index”)
/home/stoneufl/public_html/portal/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main(“OC\Setting … r”, “index”, OC\AppFramew … {}, { section: " … "})
OC\AppFramework\Routing\RouteActionHandler->__invoke({ section: " … "})
/home/stoneufl/public_html/portal/lib/private/Route/Router.php - line 297:
call_user_func(OC\AppFramew … {}, { section: " … "})
/home/stoneufl/public_html/portal/lib/base.php - line 997:
OC\Route\Router->match("/settings/admin/sharing")
/home/stoneufl/public_html/portal/index.php - line 42:
OC::handleRequest()
Thanks.
