"Shared with others" empty after upgrade to Postgresql 16 using pg_upgradecluster
When I upgrade from postgresql 15.5 to 16.1:
  • “Shared with others” is empty
  • “Shared with me” shows many entries
Background
I switched from mysql to postgresql 10 in 2021.
Since then I have painlessly upgraded postgresql using “pg_upgradecluster…”
System
Nextcloud version(s): 27.1.3, 27.1.4
Ubuntu 22.04.3 LTS
vmware guest / snapshot restored after each unsuccessful attempt
user backend: database
Steps to upgrade the database
sudo -u www-data php /var/www/nextcloud/occ maintenance:mode --on
sudo systemctl restart php8.2-fpm
sudo pg_dropcluster --stop 16 main
sudo pg_upgradecluster 15 main
sudo -u www-data php /var/www/nextcloud/occ maintenance:mode --off
After the database upgrade nextcloud appears functional except that “Shared with others” is empty.
Unsuccessful Steps Taken
The “oc_shares” table seems to be OK; this command returns the same counts before and after the upgrade:
psql -t -c "select share_type from oc_share;" -e nextcloud |sort |uniq -c
pg_upgradecluster mentions a comment about a new default collation order:
DETAIL:  The database was created using collation version 2.27, but the operating system provides version 2.35.
HINT:  Rebuild all objects in this database that use the default collation and run ALTER DATABASE postgres REFRESH COLLATION VERSION, or build PostgreSQL with the right library version.
WARNING:  database "postgres" has a collation version mismatch
The interwebs point to these commands to fix the collation -
  • “template1” continues to throw errors unless included in the repairs
  • This does not affect the problem with “Shared with others”
psql
\c nextcloud
reindex database nextcloud;
alter database nextcloud refresh collation version;
\c template1
reindex database template1;
alter database template1 refresh collation version;
I tried upgrading the database using “pg_dumpall” as described in this percona post, but that created a problem with the database user that I did not pursue.
