Shared Hosting - Missing index
Hi there,
i am using Nextcloud on a shared Hosting without SSH access, so i am not able to use occ.
I have to add some new Indexes and so on with phpmyadmin.
Maybe someone can help me with the right commands?
Missing Index:
  • Fehlender Index “fs_size” in der Tabelle “oc_filecache”.
  • Fehlender Index “calendarobject_calid_index” in der Tabelle “oc_calendarobjects_props”.
  • Fehlender Index “schedulobj_principuri_index” in der Tabelle “oc_schedulingobjects”.
  • Fehlender Index “properties_path_index” in der Tabelle “oc_properties”.
Missing column:
  • Fehlende optionale Spalte “reference_id” in der Tabelle “oc_comments”.
Missing convertion to big int:
  • filecache_extended.fileid
  • mounts.storage_id
  • mounts.root_id
  • mounts.mount_id
i have already found/used this:
but those commands are only for some of the missing indixes.
