example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.1
Operating system and version (eg, Ubuntu 20.04): ubuntu-server 22.04.1
Apache or nginx version (eg, Apache 2.4.25): NGinx
PHP version (eg, 7.4): PHP 8.1.x
- click a folder “share symbol” and open the details page for sharing
- choice a user who can authorize to your nextcloud
- deactivate further sharing, just allow downloading
- set also a time period of validity
- remark that no calender opens to choice your end date for the share
- remark also that the “set period” choice is deactivated by nextcloud next time you check your settings in that share
No Logs that give a hint to that problem found
Nor error messages in WebUI when setting the share options
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
I have triied both setting the general period of 7 days within admin pages and also deactivating this option to let each user choice him or herself which time period should the share be valid.
Nothing change that behaviour. It is new to 25.0.1 (under 24.0.7 before it was no problem → a calendar field was aware to set the end time.
Any one else that in 25.0.1
For your understanding, the share itself is visible for the user i share the folder with under his / her shared files folder.
Only the “elapse time” can’t be configured properly so far as i could test.
Append:
Within the nextcloud client for android (Version 3.23.0)
Setting elapse time period is possible and if doing so under android, a field for setting date is visible as well in the webui.
But the date set under android is not visible in the webUI → looks like you set it the first time for this share, so the field shows dd.mm.jjjj as option only.
Sharing another folder or file first time same behaviour. Sharing under WebUI (no expire date possible). Modify share under Android → then in both Clients expire date for the share possible.
Also a clear browser cache didn’t solve this problem.
