Nextcloud version 19.0.0:
Operating system and version Ubuntu 18.04.4 LTS:
Apache or nginx version Apache:
PHP version 7.3.18:
example
longer
example
here
Nextcloud version (eg, 18.0.2):
Operating system and version (eg, Ubuntu 20.04):
PHP version (eg, 7.1):
PASTE HERE
PASTE HERE
PASTE HERE
My server updated (snap) itself this morning and since then I do not have access anymore to my S3 buckets from Wasabi.
Log:
[PHP] Error: Declaration of OC\Files\ObjectStore\S3Signature::presign(Psr\Http\Message\RequestInterface $request, Aws\Credentials\CredentialsInterface $credentials, $expires) must be compatible with Aws\Signature\SignatureInterface::presign(Psr\Http\Message\RequestInterface $request, Aws\Credentials\CredentialsInterface $credentials, $expires, array $options = Array) at /snap/nextcloud/21796/htdocs/lib/private/Files/ObjectStore/S3Signature.php#36
This issue seems to be the cause:
Since that is reported 3 weeks ago, but in meantime it is not solved.
I can´t change the S3Signature.php since it is read-only.
Looks like “$options = []” needs be added ?
Since Wasabi buckets are our main storage, it is completely not usable now
Any suggestions?
kinds regards
BorisdeFloris
