Nextcloud version: 18.0.3 & 18.0.2
Operating system and version: debian
Apache or nginx version: nginx 1.17.8
PHP version: 7.3.14
Since version 18.0.2 I noticed several small problems (all tested with firefox and chromium):
hovering favorites and shares in the sidebar has a weird hover effect (external storage, newest and all files are normal)
EDIT: This is no Bug, I just did not notice that these can be expanded. -
The new file menu is slightly outside the screen for public shares:
Creating a file called “test.java” will open the editor with infinite loading icon and this error in the console:
TypeError: can't define property "compiled": Object is not extensible[core.js:597:4](webpack:///node_modules/lowlight/lib/core.js)
The text for sorting by modified date is behind the icon for changing the display mode from list to grid view (possibly only with german language).
Are these bugs known? I couldn’t find the editor opening bug anywhere, so it seems more likely there is something wrong with my configuration.
Only a bunch of these messages, which seem unrelated:
[no app in context] Debug: Deprecated event type for \OCP\Files::postWrite: Symfony\Component \EventDispatcher\GenericEvent
'default_language' => 'de',
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => '',
'datadirectory' => '/home/data/owncloud/',
'overwrite.cli.url' => '',
'version' => '18.0.3.0',
'dbname' => 'app_owncloud',
'dbhost' => 'localhost',
'dbuser' => 'app_owncloud',
'dbpassword' => '',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => '',
'mail_domain' => '',
'log_rotate_size' => 1000000,
'loglevel' => 0,
'appstore.experimental.enabled' => true,
'skeletondirectory' => '',
'knowledgebaseenabled' => false,
'redis' =>
'port' => 0,
'timeout' => 0.0,
'has_rebuilt_cache' => true,
'theme' => '',
'updater.secret' => ''
