Please help me, I have nextcloud of the raspberry pi and if I go under the admin via the web interface, then the “nekstklaudpi” option is available to me, which leads to the global settings of the system. Its very convenient.
I recently put another nextcloud on ubuntu. I put all the modules (Apache, php, database, nextcloud itself) manually. Everything works, but there is no option in the web interface that leads to global settings. How to enable it? or all settings only through the command line?
I apologize, but you didn’t understand … I do not need avatar settings, me need global settings nextcloud in web interface.
In Pi i can open global setting (see above), example…
