Two years ago I tried to start with Nextcloud, but it didn’t work for me. Last week I decided to give it a retry.
I am using Ubuntu 18.04 LTS and installed NC using the manual at https://www.scaleway.com/en/docs/configure-nextcloud/
I like to connect my other cloud storage (Dropbox) onto my NC instance, but I can not find the Apps section in my NextCloud. Where can I find it?
After working a few hours the logging of NC reports a few problems. I do not know how to solve these problems. Can anyone help me?
The errors are:
[PHP] Error: stat(): stat failed for /var/snap/nextcloud/common/nextcloud/data/appdata_ocr843j1rut0/preview/9/500-500-max.png at /snap/nextcloud/16739/htdocs/lib/private/Files/Storage/Local.php#143
GET /index.php/core/preview?fileId=9&c=94c9849d3d6c872f0b13011c4c9c2a96&x=250&y=250&forceIcon=0
from 192.168.2.254 by guido at 2019-11-06T12:55:13+00:00
[PHP] Error: Undefined index: urlGenerator at /snap/nextcloud/16739/htdocs/core/templates/loginflowv2/done.php#29
POST /index.php/login/v2/grant
from 192.168.2.254 by guido at 2019-11-06T10:45:15+00:00
[no app in context] Error: Swift_TransportException: Connection could not be established with host 127.0.0.1 [Connection refused #111] at <>
- /snap/nextcloud/16739/htdocs/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/StreamBuffer.php line 58
Swift_Transport_StreamBuffer->establishSocketConnection() - /snap/nextcloud/16739/htdocs/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Transport/AbstractSmtpTransport.php line 143
Swift_Transport_StreamBuffer->initialize({protocol: "*** … ]}) - /snap/nextcloud/16739/htdocs/3rdparty/swiftmailer/swiftmailer/lib/classes/Swift/Mailer.php line 65
Swift_Transport_AbstractSmtpTransport->start() - /snap/nextcloud/16739/htdocs/lib/private/Mail/Mailer.php line 180
Swift_Mailer->send(Swift_Message {}, []) - /snap/nextcloud/16739/htdocs/settings/Hooks.php line 217
OC\Mail\Mailer->send(OC\Mail\Message {}) - /snap/nextcloud/16739/htdocs/settings/Application.php line 209
OC\Settings\Hooks->onChangeEmail("*** sensitive parameter replaced ", " sensitive parameter replaced ***") - /snap/nextcloud/16739/htdocs/lib/private/legacy/hook.php line 106
OC\Settings\Application->onChangeInfo({run: true,user: … "}) - /snap/nextcloud/16739/htdocs/lib/private/Server.php line 431
OC_Hook::emit(“OC_User”, “changeUser”, {run: true,user: … "}) - <>
OC\Server->OC{closure}("*** sensitive parameters replaced ***") - /snap/nextcloud/16739/htdocs/lib/private/Hooks/EmitterTrait.php line 99
undefinedundefinedcall_user_func_array(Closure {}, ["*** sensitive … "]) - /snap/nextcloud/16739/htdocs/lib/private/Hooks/PublicEmitter.php line 36
OC\Hooks\BasicEmitter->emit("\OC\User", “changeUser”, ["*** sensitive … "]) - /snap/nextcloud/16739/htdocs/lib/private/User/User.php line 473
OC\Hooks\PublicEmitter->emit("\OC\User", “changeUser”, ["*** sensitive … "]) - /snap/nextcloud/16739/htdocs/lib/private/User/User.php line 168
OC\User\User->triggerChange("*** sensitive parameter replaced ", " sensitive parameter replaced ", " sensitive parameter replaced ***") - /snap/nextcloud/16739/htdocs/settings/Controller/UsersController.php line 407
OC\User\User->setEMailAddress("*** sensitive parameter replaced ***") - /snap/nextcloud/16739/htdocs/settings/Controller/UsersController.php line 348
OC\Settings\Controller\UsersController->saveUserSettings("*** sensitive parameter replaced ***", {displayname: {v … }}) - /snap/nextcloud/16739/htdocs/lib/private/AppFramework/Http/Dispatcher.php line 166
OC\Settings\Controller\UsersController->setUserSettings(“contacts”, “Guido van Harten”, “contacts”, “06-20394321”, “private”, “*** sensitive parameter replaced ", “contacts”, " sensitive parameter replaced ", “private”, " sensitive parameter replaced ", “private”, " sensitive parameter replaced ***”, “private”) - /snap/nextcloud/16739/htdocs/lib/private/AppFramework/Http/Dispatcher.php line 99
OC\AppFramework\Http\Dispatcher->executeController(OC\Settings\Controller\UsersController {}, “setUserSettings”) - /snap/nextcloud/16739/htdocs/lib/private/AppFramework/App.php line 126
OC\AppFramework\Http\Dispatcher->dispatch(OC\Settings\Controller\UsersController {}, “setUserSettings”) - /snap/nextcloud/16739/htdocs/lib/private/AppFramework/Routing/RouteActionHandler.php line 47
OC\AppFramework\App::main(“OC\Settings\C … r”, “setUserSettings”, OC\AppFramework\ … {}, {username: "guid … "}) - <>
OC\AppFramework\Routing\RouteActionHandler->__invoke({username: "guid … "}) - /snap/nextcloud/16739/htdocs/lib/private/Route/Router.php line 297
undefinedundefinedcall_user_func(OC\AppFramework\ … {}, {username: "guid … "}) - /snap/nextcloud/16739/htdocs/lib/base.php line 975
OC\Route\Router->match("/settings/users/guido/settings") - /snap/nextcloud/16739/htdocs/index.php line 42
OC::handleRequest()
PUT /index.php/settings/users/guido/settings
from 192.168.2.254 by guido at 2019-11-06T10:19:09+00:00
GET /index.php/core/preview?fileId=9&x=32&y=32
from 192.168.2.254 by guido at 2019-11-06T10:14:38+00:00
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
1 =>
'path' => '/var/snap/nextcloud/current/nextcloud/extra-apps',
'url' => '/extra-apps',
'writable' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'passwordsalt' => '**********',
'secret' => '**********',
0 => 'localhost',
1 => 'm**.v***.net',
'datadirectory' => '/var/snap/nextcloud/common/nextcloud/data',
'version' => '16.0.5.1',
'apps_paths' =>
0 =>
'url' => '/apps',
1 =>
'writable' => true,
0 => 'mysql',
'redis' =>
'port' => 0,
0 => 'localhost',
1 => 'm**.v***.***',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => '**********',
'dbpassword' => '**********',
'instanceid' => '**********',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => '**********',
'mail_domain' => '**********',
'mail_smtpauthtype' => 'PLAIN',
'mail_smtpauth' => 1,
'mail_smtphost' => '**********',
'mail_smtpport' => '**********',
'mail_smtpname' => '**********',
'mail_smtppassword' => '**********',
(it is OK that the lines 1 - 38 are duplicated in the lines 39-76?
I don’t have that file.
Best regards,
Guido van Harten
