I canât log into the web interface with different accounts. So far, I havenât figured out one I still can log in. However, I noticed that some syncs and ways to access my data work again. Notes, calendar items and contacts are synced on my Android phone. I can also access the files via the Android Nextcloud App. The desktop computer sync client doesnât work.
The last app I installed is âPasswordsâ a couple of days ago. But Nextcloud didnât break as soon as I installed it. It kept working totally fine.
I use an image installation.
Nextcloud logs
{"reqId":"Yz0ajfN1freIXPA5O9DFyAAAABM","level":2,"time":"2022-10-05T05:47:57+00:00","remoteAddr":"192.***REMOVED SENSITIVE VALUE***.152","user":"--","app":"core","method":"GET","url":"/ReportServer","message":"Trusted domain error. \"192.***REMOVED SENSITIVE VALUE***.152\" tried to access using \"188.***REMOVED SENSITIVE VALUE***.236\" as host.","userAgent":"Mozilla/5.0 zgrab/0.x","version":"24.0.5.1","data":{"app":"core"}}
{"reqId":"Yz0amvN1freIXPA5O9DFyQAAABU","level":2,"time":"2022-10-05T05:48:10+00:00","remoteAddr":"192.***REMOVED SENSITIVE VALUE***.190","user":"--","app":"core","method":"GET","url":"/login","message":"Trusted domain error. \"192.***REMOVED SENSITIVE VALUE***.190\" tried to access using \"188.***REMOVED SENSITIVE VALUE***.236\" as host.","userAgent":"Mozilla/5.0 zgrab/0.x","version":"24.0.5.1","data":{"app":"core"}}
{"reqId":"Yz0bA-osH8dbYtD06eFALQAAAI0","level":2,"time":"2022-10-05T05:49:55+00:00","remoteAddr":"193,***REMOVED SENSITIVE VALUE***.210","user":"--","app":"core","method":"GET","url":"/","message":"Trusted domain error. \"193.***REMOVED SENSITIVE VALUE***.210\" tried to access using \"188.***REMOVED SENSITIVE VALUE***.236\" as host.","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36","version":"24.0.5.1","data":{"app":"core"}}
{"reqId":"Yz0eveosH8dbYtD06eFALgAAAJA","level":2,"time":"2022-10-05T06:05:49+00:00","remoteAddr":"152.***REMOVED SENSITIVE VALUE***.23","user":"--","app":"core","method":"GET","url":"/remote/fgt_lang?lang=/../../../..//////////dev/cmdb/sslvpn_websession","message":"Trusted domain error. \"152.***REMOVED SENSITIVE VALUE***.23\" tried to access using \"188.***REMOVED SENSITIVE VALUE***.236:443\" as host.","userAgent":"Python-urllib/3.8","version":"24.0.5.1","data":{"app":"core"}}
{"reqId":"Yz0j2vN1freIXPA5O9DFygAAABc","level":2,"time":"2022-10-05T06:27:38+00:00","remoteAddr":"85.***REMOVED SENSITIVE VALUE***.69","user":"--","app":"core","method":"GET","url":"/","message":"Trusted domain error. \"85.***REMOVED SENSITIVE VALUE***.69\" tried to access using \"188.***REMOVED SENSITIVE VALUE***.236\" as host.","userAgent":"--","version":"24.0.5.1","data":{"app":"core"}}
{"reqId":"Yz0mN_N1freIXPA5O9DFzAAAAAI","level":2,"time":"2022-10-05T06:37:43+00:00","remoteAddr":"87.***REMOVED SENSITIVE VALUE***.68","user":"--","app":"core","method":"GET","url":"/","message":"Trusted domain error. \"87.***REMOVED SENSITIVE VALUE***.68\" tried to access using \"188.***REMOVED SENSITIVE VALUE***.236\" as host.","userAgent":"Mozilla/5.0 (compatible; InternetMeasurement/1.0; +https://internet-measurement.com/)","version":"24.0.5.1","data":{"app":"core"}}
{"reqId":"Yz2k-90cCX3_c8_cRXdDigAAAgQ","level":2,"time":"2022-10-05T15:38:35+00:00","remoteAddr":"194.187.160.94","user":"--","app":"no app in context","method":"POST","url":"/index.php/login","message":"Login failed: (Remote IP: 194.***REMOVED SENSITIVE VALUE***.94)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/102.0.0.0 Safari/537.36","version":"24.0.5.1","data":[]}
{"reqId":"Yz3N9N0cCX3_c8_cRXdD_QAAAAs","level":2,"time":"2022-10-05T18:33:24+00:00","remoteAddr":"188.***REMOVED SENSITIVE VALUE***.236","user":"user","app":"no app in context","method":"HEAD","url":"/remote.php/dav/files/user//Photos/2022/10/IMG_20221005_200449.jpg","message":"File with name /Photos/2022/10/IMG_20221005_200449.jpg could not be located","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.21.1","version":"24.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Photos/2022/10/IMG_20221005_200449.jpg could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":78,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/DAV/ViewOnlyPlugin.php","line":75,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkViewOnly","class":"OCA\\DAV\\DAV\\ViewOnlyPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpHead","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":242,"message":"File with name /Photos/2022/10/IMG_20221005_200449.jpg could not be located","exception":{},"CustomMessage":"File with name /Photos/2022/10/IMG_20221005_200449.jpg could not be located"}}
{"reqId":"Yz3N-QEIzYv7QEKI_ZcW2AAAAFg","level":2,"time":"2022-10-05T18:33:30+00:00","remoteAddr":"188.***REMOVED SENSITIVE VALUE***.236","user":"user","app":"no app in context","method":"HEAD","url":"/remote.php/dav/files/user//Photos/2022/10/IMG_20221005_200439.jpg","message":"File with name /Photos/2022/10/IMG_20221005_200439.jpg could not be located","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.21.1","version":"24.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Photos/2022/10/IMG_20221005_200439.jpg could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":78,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/DAV/ViewOnlyPlugin.php","line":75,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkViewOnly","class":"OCA\\DAV\\DAV\\ViewOnlyPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpHead","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":242,"message":"File with name /Photos/2022/10/IMG_20221005_200439.jpg could not be located","exception":{},"CustomMessage":"File with name /Photos/2022/10/IMG_20221005_200439.jpg could not be located"}}
{"reqId":"Yz3N_t0cCX3_c8_cRXdEDQAAAAI","level":2,"time":"2022-10-05T18:33:34+00:00","remoteAddr":"188.***REMOVED SENSITIVE VALUE***.236","user":"user","app":"no app in context","method":"HEAD","url":"/remote.php/dav/files/user//Photos/2022/10/IMG_20221005_200424.jpg","message":"File with name /Photos/2022/10/IMG_20221005_200424.jpg could not be located","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.21.1","version":"24.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Photos/2022/10/IMG_20221005_200424.jpg could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":78,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/DAV/ViewOnlyPlugin.php","line":75,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkViewOnly","class":"OCA\\DAV\\DAV\\ViewOnlyPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpHead","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":242,"message":"File with name /Photos/2022/10/IMG_20221005_200424.jpg could not be located","exception":{},"CustomMessage":"File with name /Photos/2022/10/IMG_20221005_200424.jpg could not be located"}}
{"reqId":"Yz3OCQEIzYv7QEKI_ZcW4wAAAEw","level":2,"time":"2022-10-05T18:33:45+00:00","remoteAddr":"188.***REMOVED SENSITIVE VALUE***.236","user":"user","app":"no app in context","method":"HEAD","url":"/remote.php/dav/files/user//Photos/2022/10/IMG_20221005_200328.jpg","message":"File with name /Photos/2022/10/IMG_20221005_200328.jpg could not be located","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.21.1","version":"24.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Photos/2022/10/IMG_20221005_200328.jpg could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":78,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/DAV/ViewOnlyPlugin.php","line":75,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkViewOnly","class":"OCA\\DAV\\DAV\\ViewOnlyPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpHead","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":242,"message":"File with name /Photos/2022/10/IMG_20221005_200328.jpg could not be located","exception":{},"CustomMessage":"File with name /Photos/2022/10/IMG_20221005_200328.jpg could not be located"}}
{"reqId":"Yz3OD90cCX3_c8_cRXdEEwAAABI","level":2,"time":"2022-10-05T18:33:51+00:00","remoteAddr":"188.***REMOVED SENSITIVE VALUE***.236","user":"user","app":"no app in context","method":"HEAD","url":"/remote.php/dav/files/user//Photos/2022/10/IMG_20221005_200336.jpg","message":"File with name /Photos/2022/10/IMG_20221005_200336.jpg could not be located","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.21.1","version":"24.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Photos/2022/10/IMG_20221005_200336.jpg could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":78,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/DAV/ViewOnlyPlugin.php","line":75,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkViewOnly","class":"OCA\\DAV\\DAV\\ViewOnlyPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpHead","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":242,"message":"File with name /Photos/2022/10/IMG_20221005_200336.jpg could not be located","exception":{},"CustomMessage":"File with name /Photos/2022/10/IMG_20221005_200336.jpg could not be located"}}
{"reqId":"Yz3OFN0cCX3_c8_cRXdEGQAAAAw","level":2,"time":"2022-10-05T18:33:56+00:00","remoteAddr":"188.***REMOVED SENSITIVE VALUE***.236","user":"user","app":"no app in context","method":"HEAD","url":"/remote.php/dav/files/user//Photos/2022/10/IMG_20221005_200332.jpg","message":"File with name /Photos/2022/10/IMG_20221005_200332.jpg could not be located","userAgent":"Mozilla/5.0 (Android) Nextcloud-android/3.21.1","version":"24.0.5.1","exception":{"Exception":"Sabre\\DAV\\Exception\\NotFound","Message":"File with name /Photos/2022/10/IMG_20221005_200332.jpg could not be located","Code":0,"Trace":[{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php","line":78,"function":"getChild","class":"OCA\\DAV\\Connector\\Sabre\\Directory","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/DAV/ViewOnlyPlugin.php","line":75,"function":"getNodeForPath","class":"Sabre\\DAV\\Tree","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"checkViewOnly","class":"OCA\\DAV\\DAV\\ViewOnlyPlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php","line":251,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/event/lib/WildcardEmitterTrait.php","line":89,"function":"httpHead","class":"Sabre\\DAV\\CorePlugin","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":472,"function":"emit","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":253,"function":"invokeMethod","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php","line":321,"function":"start","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/lib/Server.php","line":358,"function":"exec","class":"Sabre\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/apps/dav/appinfo/v2/remote.php","line":35,"function":"exec","class":"OCA\\DAV\\Server","type":"->"},{"file":"/var/www/nextcloud/remote.php","line":166,"args":["/var/www/nextcloud/apps/dav/appinfo/v2/remote.php"],"function":"require_once"}],"File":"/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php","Line":242,"message":"File with name /Photos/2022/10/IMG_20221005_200332.jpg could not be located","exception":{},"CustomMessage":"File with name /Photos/2022/10/IMG_20221005_200332.jpg could not be located"}}
