Could anybody take a look at these changes?
This should fill in the OS field in serverinfo which is currently blank.
https://…/nextcloud/index.php/settings/admin/serverinfo
Thank you.
diff -ur nextcloud-old/apps/serverinfo/lib/OperatingSystems/DefaultOs.php nextcloud-new/apps/serverinfo/lib/OperatingSystems/DefaultOs.php --- nextcloud-old/apps/serverinfo/lib/OperatingSystems/DefaultOs.php 2020-01-17 14:47:00.000000000 +0100 +++ nextcloud-new/apps/serverinfo/lib/OperatingSystems/DefaultOs.php 2020-01-29 20:32:07.538029299 +0100 @@ -46,6 +46,14 @@ /** * @return string */ + public function getOSName() { + $osname = php_uname(); + return $osname; + } + + /** + * @return string + */ public function getMemory() { $memory = shell_exec('cat /proc/meminfo | grep -i \'MemTotal\' | cut -f 2 -d ":" | awk \'{$1=$1}1\''); $memory = explode(' ', $memory); diff -ur nextcloud-old/apps/serverinfo/lib/Os.php nextcloud-new/apps/serverinfo/lib/Os.php --- nextcloud-old/apps/serverinfo/lib/Os.php 2020-01-17 14:47:00.000000000 +0100 +++ nextcloud-new/apps/serverinfo/lib/Os.php 2020-01-29 20:30:39.463442268 +0100 @@ -93,7 +93,7 @@ * @return string */ public function getOSName() { - $data = $this->osname; + $data = $this->backend->getOSName(); return $data; }
BTW
Doesn’t reading from /sys and /proc cause any compatibility issues on systems other than linux?
