Hi everyone!
I created a DigitalOcean server with a 250GB volume (block storage)
The volume is mounted at: /mnt/volume-tor1-01/data/
This mounted volume is defined in the config.php and it works really well.
One issue that I came across is that when I select all the encryption options:
Enable Server-Side Encryption
Default encryption module
Encrypt home directory
However, when I look at my files via SSH, they are still not encrypted.
Any solutions?
Thanks!
