Nextcloud AIO 24.0.6
PHP 8.0.24
PostgreSQL 14.5
On Linux Mint 20.3 Docker Kernel 5.4.0**
24GB ram, I7 Intel.
I have about 800+ contacts. Searching for contact NAMES seem to work fine, but searching for numbers does not.
In the web interface Home>Contacts there is a search box. I type an area code which is about 40% of the numbers on my list, and only 4 contacts come up in the result… A second area code (50
% of the other contacts), brings 5 results only.
I can try the last 4 numbers of a random phone number on the list, and nothing is found.
I use a VOIP service where my contacts are not uploaded to, so every now and then i need to search for numbers to see if is one of my contacts.
Is there anyway to tell nextcloud to index numbers, not just the names?
Thank you
