Super quick question I’m pretty sure I already know the answer to, but am not willing to risk screwing up. If I enable NFTS Encrypting File System (EFS) (right click > Properties > Advanced > Encrypt this folder (and its contents) that is operating system level encryption unlocked on login, so the nextcloud app will still sync just fine, and my files on the server won’t be encrypted with my EFS key, right?
Probably. I’d just check on the webinterface on a few files if they are encrypted or not (just where I have doubt is if your session is active but you need the password to reactivate, if the desktop client remains active…).
