Saml encryption issue
example
longer
example
here
Nextcloud version (eg, 20.0.5): Nextcloud Hub 5 (27.0.2)
Operating system and version (eg, Ubuntu 20.04): Arch Linux rolling
Apache or nginx version (eg, Apache 2.4.25): nginx/1.25.1
PHP version (eg, 7.4): php 8.2.8
All these run in docker containers “nextcloud:fpm-alpine, nginx:alpine, redis:alpine, mariadb:latest”
When using keycloak saml login to nextcloud, with long back disabled encryption
# occ encryption:status
  - enabled: false
  - defaultModule: OC_DEFAULT_MODULE
Is this the first time you’ve seen this error? (Y/N): Yes
  1. setup an encryption at NC version 20, then disable it
  2. implement saml SSO setup with keycloak 20+
  3. get an
[PHP] Error: TypeError: OCA\Encryption\Crypto\Crypt::generatePasswordHash(): Argument #1 ($password) must be of type string, null given, called in /var/www/html/apps/encryption/lib/Crypto/Crypt.php on line 435 at /var/www/html/apps/encryption/lib/Crypto/Crypt.php#374
GET /ocs/v2.php/apps/notifications/api/v2/notifications
  'passwordsalt' => '************',
  'secret' => '*********',
  'trusted_proxies' =>
    0 => '192.168.******',
  'overwrite.cli.url' => 'https://********/',
  'overwritecondaddr' => '',
  'version' => '27.0.2.1',
  'debug' => false,
  'dbname' => 'nextcloud',
  'dbhost' => 'mariadb',
  'dbport' => '3306',
  'dbuser' => 'nextcloud',
  'dbpassword' => '**************',
  'logtimezone' => 'UTC',
  'instanceid' => '*******',
  'singleuser' => false,
  'theme' => '',
  'loglevel' => 1,
  'mail_smtpmode' => 'smtp',
  'mail_smtpauthtype' => 'PLAIN',
  'mail_domain' => '*****',
  'log_type' => 'file',
  'mail_sendmailmode' => 'pipe',
  'mail_smtpsecure' => 'tls',
  'mail_smtphost' => '*****',
  'mail_smtpport' => '25',
  'default_phone_region' => '**',
  #'encryption.legacy_format_support' => false,
  'redis' =>
    'host' => 'redis',
    'port' => 6379,
PASTE HERE
PASTE HERE
/Files/View.php","line":1352,"function":"find","class":"OC\\Files\\Mount\\Manager","type":"->","args":["/appdata_octhjg4inrv
z/js/core"]},{"file":"/var/www/html/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\
\View","type":"->","args":["/appdata_octhjg4inrvz/js/core",false]},{"function":"get","class":"OC\\Files\\Node\\Root","type":
"->","args":["/appdata_octhjg4inrvz/js/core"]},{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":73,"func
tion":"call_user_func_array","args":[[["OC\\Files\\Node\\Root"],"get"],["appdata_octhjg4inrvz/js/core"]]},{"file":"/var/www/
html/lib/private/Files/Node/LazyFolder.php","line":150,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->"
,"args":["get",["appdata_octhjg4inrvz/js/core"]]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"
function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_octhjg4inrvz/js/core"]},{"file":"/var/www
/html/lib/private/Template/JSCombiner.php","line":87,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->
","args":["core"]},{"file":"/var/www/html/lib/private/Template/JSResourceLocator.php","line":145,"function":"process","class
":"OC\\Template\\JSCombiner","type":"->","args":["/var/www/html","core/js/merged-template-prepend.json","core"]},{"file":"/v
ar/www/html/lib/private/Template/JSResourceLocator.php","line":75,"function":"cacheAndAppendCombineJsonIfExist","class":"OC\
\Template\\JSResourceLocator","type":"->","args":["/var/www/html","core/js/merged-template-prepend.json"]},{"file":"/var/www/html/lib/private/Template/ResourceLocator.php","line":73,"function":"doFind","class":"OC\\Template\\JSResourceLocator","type":"->","args":["core/js/merged-template-prepend"]},{"file":"/var/www/html/lib/private/TemplateLayout.php","line":377,"function":"find","class":"OC\\Template\\ResourceLocator","type":"->","args":[["core/js/common","core/js/main","core/l10n/en","core/js/files_fileinfo","core/js/files_client","And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/TemplateLayout.php","line":222,"function":"findJavascriptFiles","class":"OC\\TemplateLayout","type":"::","args":[["core/js/common","core/js/main","core/l10n/en","core/js/files_fileinfo","core/js/files_client","And 1 more entries, set log level to debug to see all entries"]]},{"file":"/var/www/html/lib/private/legacy/OC_Template.php","line":182,"function":"__construct","class":"OC\\TemplateLayout","type":"->","args":["guest","core"]},{"file":"/var/www/html/lib/private/Template/Base.php","line":132,"function":"fetchPage","class":"OC_Template","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":841,"function":"printPage","class":"OC\\Template\\Base","type":"->","args":[]},{"file":"/var/www/html/lib/base.php","line":1173,"function":"init","class":"OC","type":"::","args":[]},{"file":"/var/www/html/index.php","line":34,"args":["/var/www/html/lib/base.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/Files/Mount/Manager.php","Line":118,"message":"App encryption threw an error during app.php load: No mount for path /.oc_key_storage existing mounts: ","exception":{},"CustomMessage":"App encryption threw an error during app.php load: No mount for path /.oc_key_storage existing mounts: "}}
I in the past deleted the encryption files in the directories, as encryption is disabled.
As some topic recommended, that it removes the message:
“Invalid private key for encryption app. Please update your private key password in your personal settings to recover access to your encrypted files.”
When I try to change the encryption password under settings/user/security, it says that password updated successfully, but if I input my same password I use for saml login, I get an internal server error - contact your administrator page and then if I refresh, I get to the the nextcloud instance, but with the message of Invalid private key quoted above…
