Hi!
I have trouble accessible my NC instance using two different domains (olddomain.com and the more recent newnewdomain.com.
I can see there are a couple topics on the subject, but it didn’t help.
My nginx configuration seems fine. And I also added the new domain in config.php.
I can access the login page, and log in, but then when it tries to load the /app/files url, it fails, and I can see these errors in the logs:
Exception: The requested uri(/apps/files/index.php/apps/gallery/config) cannot be processed by the script '/index.php/apps/files/index.php')
/usr/share/nginx/nextcloud/lib/base.php - line 940:
OC\AppFramework\Http\Request->getRawPathInfo()
/usr/share/nginx/nextcloud/index.php - line 42:
OC::handleRequest()
And then four times the same error:
OCP\Files\NotPermittedException: No create permission for path
/usr/share/nginx/nextcloud/lib/private/Files/SimpleFS/SimpleFolder.php - line 83:
OC\Files\Node\Folder->newFile("daf8-1569-styles.css")
/usr/share/nginx/nextcloud/lib/private/Template/SCSSCacher.php - line 311:
OC\Files\SimpleFS\SimpleFolder->newFile("daf8-1569-styles.css")
/usr/share/nginx/nextcloud/lib/private/Template/SCSSCacher.php - line 181:
OC\Template\SCSSCacher->cache("/usr/share/ ... s", "daf8-1569-styles.css", "styles.scss", OC\Files\Sim ... {}, "/apps/notifications/css")
/usr/share/nginx/nextcloud/lib/private/Template/CSSResourceLocator.php - line 109:
OC\Template\SCSSCacher->process("/usr/share/ ... s", "css/styles.scss", "notifications")
/usr/share/nginx/nextcloud/lib/private/Template/CSSResourceLocator.php - line 84:
OC\Template\CSSResourceLocator->cacheAndAppendScssIfExist("/usr/share/ ... s", "css/styles.scss", "notifications")
/usr/share/nginx/nextcloud/lib/private/Template/ResourceLocator.php - line 78:
OC\Template\CSSResourceLocator->doFind("css/styles")
/usr/share/nginx/nextcloud/lib/private/TemplateLayout.php - line 305:
OC\Template\ResourceLocator->find([ "css/serve ... "])
/usr/share/nginx/nextcloud/lib/private/TemplateLayout.php - line 210:
OC\TemplateLayout::findStylesheetFiles([ "css/serve ... "])
/usr/share/nginx/nextcloud/lib/private/legacy/template.php - line 183:
OC\TemplateLayout->__construct("user", "files")
/usr/share/nginx/nextcloud/lib/public/AppFramework/Http/TemplateResponse.php - line 165:
OC_Template->fetchPage({ usedSpaceP ... ]})
/usr/share/nginx/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 123:
OCP\AppFramework\Http\TemplateResponse->render()
/usr/share/nginx/nextcloud/lib/private/AppFramework/App.php - line 126:
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Files\Co ... {}, "index")
/usr/share/nginx/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main("OCA\\Files\ ... r", "index", OC\AppFramew ... {}, { _route: "files.view.index"})
<<closure>>
OC\AppFramework\Routing\RouteActionHandler->__invoke({ _route: "files.view.index"})
/usr/share/nginx/nextcloud/lib/private/Route/Router.php - line 297:
call_user_func(OC\AppFramew ... {}, { _route: "files.view.index"})
/usr/share/nginx/nextcloud/lib/base.php - line 997:
OC\Route\Router->match("/apps/files/")
OC::handleRequest()
What did I do wrong?
Thank you all!
