Dear Comunity,
My problem is as follows:
I have created a Samba share on a MAC computer that I would like to mount as external storage in my Nextcloud. However, I get an error message every time I try. What works:
- Mounting Samba shares on Linux servers into my Nextcloud.
- Accessing the Samba share on the Mac from Windows computers.
So the problem is somehow in the configuration of my Nextcloud. Setting my Nextcloud:
- Nextcloud version 23
- PHP8
- Ubuntu 21 64 bit
- Apache 2 web server
Messages from the error log:
Error no app in context Icewind\SMB\Exception\ConnectionResetException: /
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php - line 67:
Icewind\SMB\Exception\Exception::fromMap()
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php - line 84:
Icewind\SMB\Native\NativeState->handleError()
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeState.php - line 338:
Icewind\SMB\Native\NativeState->testResult()
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php - line 305:
Icewind\SMB\Native\NativeState->getxattr()
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php - line 43:
Icewind\SMB\Native\NativeShare->getAttribute()
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeFileInfo.php - line 69:
Icewind\SMB\Native\NativeFileInfo->stat()
/var/www/html/apps/files_external/3rdparty/icewind/smb/src/Native/NativeShare.php - line 114:
Icewind\SMB\Native\NativeFileInfo->getSize()
/var/www/html/apps/files_external/lib/Lib/Storage/SMB.php - line 189:
Icewind\SMB\Native\NativeShare->stat()
/var/www/html/apps/files_external/lib/Lib/Storage/SMB.php - line 342:
OCA\Files_External\Lib\Storage\SMB->getFileInfo()
/var/www/html/lib/private/Files/Storage/Common.php - line 458:
OCA\Files_External\Lib\Storage\SMB->stat()
/var/www/html/apps/files_external/lib/Lib/Storage/SMB.php - line 717:
OC\Files\Storage\Common->test()
/var/www/html/apps/files_external/lib/MountConfig.php - line 130:
OCA\Files_External\Lib\Storage\SMB->test()
/var/www/html/apps/files_external/lib/Controller/StoragesController.php - line 270:
OCA\Files_External\MountConfig::getBackendStatus("*** sensiti ... *")
/var/www/html/apps/files_external/lib/Controller/GlobalStoragesController.php - line 120:
OCA\Files_External\Controller\StoragesController->updateStorageStatus("*** sensiti ... *")
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 217:
OCA\Files_External\Controller\GlobalStoragesController->create()
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 126:
/var/www/html/lib/private/AppFramework/App.php - line 157:
/var/www/html/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main()
/var/www/html/lib/base.php - line 1006:
OC\Route\Router->match()
/var/www/html/index.php - line 36:
OC::handleRequest()
[no app in context] Warning: External storage not available: Storage unauthorized. /
POST /apps/files_external/globalstorages
from 113.208.212.57 by Baum at 2021-12-09T15:45:21+01:00
Warning no app in context OCP\Files\StorageAuthException: Storage unauthorized. /
/var/www/html/apps/files_external/lib/Lib/Storage/SMB.php - line 193:
OCA\Files_External\Lib\Storage\SMB->throwUnavailable()
OC::handleRequest()
Caused by Icewind\SMB\Exception\ConnectionResetException: /
OC::handleRequest()
Does somebody know how to mount a Samba share on a Mac to a Nextcloud?
