[/details]
Nextcloud version (eg, 20.0.5): 25.0.1
Operating system and version (eg, Ubuntu 20.04): Debian Bullseye
Apache or nginx version (eg, Apache 2.4.25): nginx
PHP version (eg, 7.4): php-fpm 8.1
I set up a new nextcloud instance with Wasabi S3 as primary storage and ldap users. Everything worked fine, and users were created. Unfortuantely now I do have a issue that (after tranferring a amount of GB of data from the old nexcloud via external stoage) I can’t access the files on the S3-Storage anymore.
A php8.1 occ files:scan
Starting scan for user 1 out of 1 ()
Path not found: /
I got some error messages in the past
[no app in context] Fehler: OCP\Files\StorageNotAvailableException: Sabre\HTTP\ClientException: error setting certificate verify locations: CAfile: /tmp/user/33/oc_tmp_kNsdVb-.crt CApath: /etc/ssl/certs at <>
- /var/www/collaboration/lib/private/Files/Storage/DAV.php line 289
OC\Files\Storage\DAV->convertException() - /var/www/collaboration/lib/private/Files/Storage/DAV.php line 715
OC\Files\Storage\DAV->propfind() - /var/www/collaboration/lib/private/Files/Storage/Common.php line 715
OC\Files\Storage\DAV->getPermissions() - /var/www/collaboration/lib/private/Files/Storage/Common.php line 897
OC\Files\Storage\Common->getMetaData() - /var/www/collaboration/lib/private/Files/Storage/Wrapper/PermissionsMask.php line 157
OC\Files\Storage\Common->getDirectoryContent() - <>
OC\Files\Storage\Wrapper\PermissionsMask->getDirectoryContent() - /var/www/collaboration/lib/private/Files/Cache/Scanner.php line 412
iterator_to_array() - /var/www/collaboration/lib/private/Files/Cache/Scanner.php line 391
OC\Files\Cache\Scanner->handleChildren() - /var/www/collaboration/lib/private/Files/Cache/Scanner.php line 394
OC\Files\Cache\Scanner->scanChildren() - /var/www/collaboration/lib/private/Files/Cache/Scanner.php line 394
OC\Files\Cache\Scanner->scanChildren() - /var/www/collaboration/lib/private/Files/Cache/Scanner.php line 342
OC\Files\Cache\Scanner->scanChildren() - /var/www/collaboration/lib/private/Files/Utils/Scanner.php line 256
OC\Files\Cache\Scanner->scan() - /var/www/collaboration/apps/files/lib/Command/Scan.php line 161
OC\Files\Utils\Scanner->scan() - /var/www/collaboration/apps/files/lib/Command/Scan.php line 217
OCA\Files\Command\Scan->scanFiles() - /var/www/collaboration/3rdparty/symfony/console/Command/Command.php line 255
OCA\Files\Command\Scan->execute() - /var/www/collaboration/core/Command/Base.php line 177
Symfony\Component\Console\Command\Command->run() - /var/www/collaboration/3rdparty/symfony/console/Application.php line 1009
OC\Core\Command\Base->run() - /var/www/collaboration/3rdparty/symfony/console/Application.php line 273
Symfony\Component\Console\Application->doRunCommand() - /var/www/collaboration/3rdparty/symfony/console/Application.php line 149
Symfony\Component\Console\Application->doRun() - /var/www/collaboration/lib/private/Console/Application.php line 213
Symfony\Component\Console\Application->run() - /var/www/collaboration/console.php line 100
OC\Console\Application->run() - /var/www/collaboration/occ line 11
require_once(“/var/www/collaboration/console.php”)
at 2022-11-11T09:08:24+00:00
Does anybody have some hints how can I restore/access the data again and how can I make the S3 object storage more relaible in future?
thanks
