If you’re urgently looking for support to keep your business running, consider checking out our paid support options.
In order to help you as quickly as possible, before clicking Create Topic please provide as much of the following as you can (you can cut and paste this into your topic):
Nextcloud version (eg, 10.0.2): 12
Operating system and version (eg, Ubuntu 16.04): ubuntu 16.04
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.18
PHP version (eg, 5.6): 7.0
Is this the first time you’ve seen this error?: no, in Nc11(but i fix this)
Can you reliably replicate it? (If so, please outline steps):
When i insert in the config.php file the part about the objectstore following the guidelines (for amazon s3)
internal server error.
Could not create object: [curl] 60: SSL certificate problem: self signed certificate in certificate chain [url] https://xxxxxxx:8082/xxxx/urn%3Aoid%3A170
‘objectstore’ => array(
‘class’ => ‘OC\Files\ObjectStore\S3’,
‘arguments’ => array(
‘bucket’ => ‘nextcloud’,
‘autocreate’ => true,
‘key’ => ‘EJ39ITYZEUH5BGWDRUFY’,
‘secret’ => ‘M5MrXTRjkyMaxXPe2FRXMTfTfbKEnZCu+7uRTVSj’,
‘hostname’ => ‘example.com’,
‘port’ => 1234,
‘use_ssl’ => true,
‘region’ => ‘optional’,
‘use_path_style’=>true
nothing of importance
Remember, this information may be requested if it isn’t supplied; for fastest response please provide as much as you can Feel free to use a pastebin service, otherwise log files can be indented with 4 spaces on each line to present them in a friendlier way on the forum.
