Hi all,
I would like to setup my nextcloud server (on AWS t3) to use S3 as primary storage - I am not interested to have it as external storage.
i do manage to install nextcloud:
sudo snap install nextcloud
and run the initial setup (from the webpage) but as soon as I modify the config.php I do get errors like:
Your data directory is invalid Ensure there is a file called “.ocdata” in the root of the data directory.
Here the complete config.php for your reference:
'apps_paths' =>
0 =>
'path' => '/snap/nextcloud/current/htdocs/apps',
'url' => '/apps',
'writable' => false,
'objectstore' =>
'class' => '\\OC\\Files\\ObjectStore\\S3',
'arguments' =>
'bucket' => 'bucket name',
'autocreate' => true,
'key' => 'key',
'secret' => 'skey', # I did create an user role IAM with all the privilege
'use_ssl' => true,
'use_path_style' => true,
'supportedDatabases' =>
0 => 'mysql',
'redis' =>
'host' => '/tmp/sockets/redis.sock',
'port' => 0,
'instanceid' => 'oc8yk3p9idj4',
'passwordsalt' => 'U56dt76KjEzTqnqkP7F84Ob49+9kay',
'secret' => 'Go5insEtAztC47WoZ22WAJ0BZzMgm5q5OF5PxEEnflvEMQ6e',
0 => '3.137.48.123',
'version' => '18.0.4.2',
'overwrite.cli.url' => 'http://3.137.48.123',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:/tmp/sockets/mysql.sock',
'dbuser' => 'nextcloud',
'dbpassword' => 'WSsv95PGPPZWjSobE-iB',
Could someone help me ? What I am doing wrong ?
