Hello dear Nextcloud Community!
Nextcloud version (eg, 20.0.5): 23.0.3
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.4 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41 (Ubuntu)
PHP version (eg, 7.4): PHP 7.4.3
I get the following error in my nextcloud logs (accessed via NX Webinterface), every time i try to list the users of the NX Instance. They wont show up, i just geht an error message.
Is this the first time you’ve seen this error? (Y/N): No
- Open the Users Tab via NX Webinterface
- Dont select a Group, select “All Users” (users won’t show up, error message is printed)
- Lookup the NX logs
RuntimeException: Tools does not exist
/var/www/lib/private/User/Manager.php - line 196:
OC\User\Database->getRealUID()
/var/www/lib/private/User/Manager.php - line 296:
OC\User\Manager->getUserObject()
/var/www/apps/provisioning_api/lib/Controller/UsersController.php - line 187:
OC\User\Manager->search()
/var/www/lib/private/AppFramework/Http/Dispatcher.php - line 217:
OCA\Provisioning_API\Controller\UsersController->getUsersDetails()
/var/www/lib/private/AppFramework/Http/Dispatcher.php - line 126:
/var/www/lib/private/AppFramework/App.php - line 157:
/var/www/lib/private/Route/Router.php - line 302:
OC\AppFramework\App::main()
/var/www/ocs/v1.php - line 62:
OC\Route\Router->match()
/var/www/ocs/v2.php - line 23:
require_once("/var/www/ocs/v1.php")
'instanceid' => 'CENSORED',
'passwordsalt' => 'CENSORED',
'secret' => 'CENSORED',
0 => 'CENSORED',
1 => '192.168.1.217',
2 => 'CENSORED',
3 => '192.168.1.217/nextcloud',
'datadirectory' => '/var/www/data',
'version' => '23.0.3.2',
'overwrite.cli.url' => 'CENSORED',
'dbname' => 'oc',
'dbhost' => 'localhost',
'dbuser' => 'CENSORED',
'dbpassword' => 'CENSORED',
'mail_from_address' => 'mail',
'mail_smtpmode' => 'smtp',
'mail_domain' => CENSORED',
'mail_smtpauth' => 1,
'mail_smtphost' => '192.168.1.116',
'mail_smtpname' => 'CENSORED',
'mail_smtppassword' => 'CENSORED',
'theme' => '',
'loglevel' => 2,
'redis' =>
'host' => 'localhost',
'port' => 6379,
'app_install_overwrite' =>
0 => 'calendar',
'encryption.legacy_format_support' => false,
'encryption.key_storage_migrated' => false,
No specific errors
Es ist ein Fehler bei der Anfrage aufgetreten. Es kann nicht fortgefahren werden.
I’m thankful for any help.
I already tried the steps from this post: Can't display users / Sharing not possible - #7 by aecklers
I get a similar when trying to list the users via the occ user:list command:
root@nextcloud:/var/www# sudo -u www-data php occ user:list
In Database.php line 513:
user:list [-l|--limit [LIMIT]] [-o|--offset [OFFSET]] [--output [OUTPUT]] [-i|--info]
