Hi guys,
I have the following unraid docker running:
NginxProxyManager
autostart wait 0
mariadb
autostart wait 5
mariadb2
autostart wait 20
nextcloud
autostart wait 20
nextcloud2
autostart wait 20
All on bridged network.
Each nextcloud is directed to via its port from Nginx.
Each nextcloud is linked to mariaDB via separate port.
Most of the time all is running fine, but from time to time I encounter the
502 bad gateway on the NEXTCLOUD2.
Maybe once a day…
- I assumed that it was a problem of dockers starting too fast.
- I tried to have a wait time before they start. But problem appears again.
- When I stop mariaDB2 and and NEXTCLOUD2 and restart it after few seconds, it works again.
Could anyone suggest where to look for problems?
Is this the first time you’ve seen this error? (Y/N): NO
Nextcloud version: Nextcloud 22.1.1
Operating system and version : UNRAID Version: 6.9.2
Nginx version: v2.9.8 © 2021
This is the only error warning I get since it has worked:
Warning core Login failed: '67.513466269904' (Remote IP: '184.XXX.242.192')
