I’m currently running this on a 2012 MAC-mini. Basically, ensured apache server was up and running, unzipped the server files, installed in my “Sites”, set-up SSL, and went though a few login headaches. It fails all file integrity checks and I still need to work out caldav and cardDav, but the later “dav” issues were major headaches with Owncloud which I use on a currently failing NAS, but other than that it seems to be working fine natively. I’m not getting server errors and I’m exchanging & synching files between my IPAD, MACBOOKPRO and IMAC
I did attempt a docker installation, but I was never able to get SSL working with the available dockers . . . but then I didn’t try to hard. I really didn’t want the extra overhead.
