Running Nextcloud 32.0.5.0 - NOT on latest patch level
Since a few versions, every time I update my Nextcloud AIO, I still get told by the security scan I am
“NOT on latest patch level”
Does anyone know what is going on?
Hi, indeed 32.0.6 is the latest version which is currently available in AIOs beta channel and will be pushed to stable tomorrow. See GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
But today, right now, 32.0.5 is the latest - I am not on the beta channel.
Yes indeed. v32.0.6 is still in the beta channel and will be pushed to the latest channel tomorrow.
So that is probably not the cause of my problem.
No, the latest version of Nextcloud is 32.0.6, but it has not yet been released on AIO’s stable channel.
I’d say that’s exactly the cause of your “problem.” The security scanner detected 32.0.5 and therefore correctly states that this is not the latest patch version. As soon as the update to 32.0.6 is released to the AIO stable channel, according to @szaimen post at some point today, you can update your instance and the problem will be solved.
AIO v12.7.0 was just released that contains Nextcloud 32.0.6: https://github.com/nextcloud/all-in-one/releases/tag/v12.7.0
