Hi, I’m installing Nextcloud (26 and 27) with docker-compose. My problem is I’m trying to config the ldap user settings during setup. I have tested app-hooks but the user_ldap does not seem to be available during the setup.
I can enable the user_ldap app in a script in app-hooks/post-installation but how/when to run “php /var/www/html/occ ldap:set-config s01…”? If I run it in a post-installation script I only get “Invalid configID”.
Are you creating an empty config to set first?
I.e. occ ldap:create-empty-config
See here:
