Hello, the administration tells me that an update to 15.0.2 is available.
There is missing updating below:
NextcloudPi
I read that an update via the WebUpdater is not recommended, what is the right way to update to 15.0.2?
NextcloudPi
The recommended way for NCP users to update NC is:
First use (either through ncp-config or ncp-web:4443):
nc-update or enable nc-autoupdate-ncp (recommended) to update NCP to latest version (currently v1.4.11)
then run
nc-update-nextcloud (or enable nc-autoupdate-nc (recommended) to update NC
When both autoupdates are enabled, it will check for and update to the latest versions within and every 24hrs.
Thanks for your Help, the Update to 15.0.2 goes without Problem’s, everthing looks good.
