Ah yes! Sorry and thank you for your reply!
Nextcloud version: 24.0.4
Nexctcloud AIO: 1.7.1
OS: Ubuntu 22.04
WebServer: Apache 2.4.54
PHP: 8.0.22
DB: Postgre SQL 14.5
Approval app version: 1.0.10
LibreSign app version: 5.1.4
Log file entries that might be of interest to the LibreSign issue:
{"reqId":"033EhRzLvm4WtBhlBM3o","level":3,"time":"2022-08-25T16:49:54+00:00","remoteAddr":"172.17.0.1","user":"admin","app":"PHP","method":"POST","url":"/settings/apps/enable","message":"Undefined variable $install at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#30","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.4.1","exception":{"Exception":"Error","Message":"Undefined variable $install at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#30","Code":0,"Trace":[{"file":"/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php","line":30,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined variable $install","/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php",30]},{"function":"__construct","class":"OCA\\Libresign\\Migration\\Version2040Date20211027183759","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OCA\\Libresign\\Migration\\Version2040Date20211027183759"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/ServerContainer.php","line":145,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":498,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":450,"function":"createInstance","class":"OC\\DB\\MigrationService","type":"->","args":["2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":417,"function":"migrateSchemaOnly","class":"OC\\DB\\MigrationService","type":"->","args":["latest"]},{"file":"/var/www/html/lib/private/Installer.php","line":154,"function":"migrate","class":"OC\\DB\\MigrationService","type":"->","args":["latest",true]},{"file":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","line":451,"function":"installApp","class":"OC\\Installer","type":"->","args":["libresign"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"enableApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":[["libresign"],[]]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AppSettingsController","enableApps",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},["settings.AppSettings.enableApps"]]},{"file":"/var/www/html/lib/base.php","line":1023,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/apps/enable"]},{"file":"/var/www/html/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"033EhRzLvm4WtBhlBM3o","level":3,"time":"2022-08-25T16:49:54+00:00","remoteAddr":"172.17.0.1","user":"admin","app":"PHP","method":"POST","url":"/settings/apps/enable","message":"Undefined variable $config at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#31","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.4.1","exception":{"Exception":"Error","Message":"Undefined variable $config at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#31","Code":0,"Trace":[{"file":"/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php","line":31,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined variable $config","/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php",31]},{"function":"__construct","class":"OCA\\Libresign\\Migration\\Version2040Date20211027183759","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OCA\\Libresign\\Migration\\Version2040Date20211027183759"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/ServerContainer.php","line":145,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":498,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":450,"function":"createInstance","class":"OC\\DB\\MigrationService","type":"->","args":["2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":417,"function":"migrateSchemaOnly","class":"OC\\DB\\MigrationService","type":"->","args":["latest"]},{"file":"/var/www/html/lib/private/Installer.php","line":154,"function":"migrate","class":"OC\\DB\\MigrationService","type":"->","args":["latest",true]},{"file":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","line":451,"function":"installApp","class":"OC\\Installer","type":"->","args":["libresign"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"enableApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":[["libresign"],[]]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AppSettingsController","enableApps",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},["settings.AppSettings.enableApps"]]},{"file":"/var/www/html/lib/base.php","line":1023,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/apps/enable"]},{"file":"/var/www/html/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"033EhRzLvm4WtBhlBM3o","level":3,"time":"2022-08-25T16:49:54+00:00","remoteAddr":"172.17.0.1","user":"admin","app":"PHP","method":"POST","url":"/settings/apps/enable","message":"Undefined variable $systemConfig at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#32","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.4.1","exception":{"Exception":"Error","Message":"Undefined variable $systemConfig at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#32","Code":0,"Trace":[{"file":"/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php","line":32,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined variable $systemConfig","/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php",32]},{"function":"__construct","class":"OCA\\Libresign\\Migration\\Version2040Date20211027183759","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OCA\\Libresign\\Migration\\Version2040Date20211027183759"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/ServerContainer.php","line":145,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":498,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":450,"function":"createInstance","class":"OC\\DB\\MigrationService","type":"->","args":["2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":417,"function":"migrateSchemaOnly","class":"OC\\DB\\MigrationService","type":"->","args":["latest"]},{"file":"/var/www/html/lib/private/Installer.php","line":154,"function":"migrate","class":"OC\\DB\\MigrationService","type":"->","args":["latest",true]},{"file":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","line":451,"function":"installApp","class":"OC\\Installer","type":"->","args":["libresign"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"enableApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":[["libresign"],[]]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AppSettingsController","enableApps",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},["settings.AppSettings.enableApps"]]},{"file":"/var/www/html/lib/base.php","line":1023,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/apps/enable"]},{"file":"/var/www/html/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"033EhRzLvm4WtBhlBM3o","level":3,"time":"2022-08-25T16:49:54+00:00","remoteAddr":"172.17.0.1","user":"admin","app":"PHP","method":"POST","url":"/settings/apps/enable","message":"Undefined variable $rootfolder at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#33","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.0.0 Safari/537.36","version":"24.0.4.1","exception":{"Exception":"Error","Message":"Undefined variable $rootfolder at /var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php#33","Code":0,"Trace":[{"file":"/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php","line":33,"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"Undefined variable $rootfolder","/var/www/html/custom_apps/libresign/lib/Migration/Version2040Date20211027183759.php",33]},{"function":"__construct","class":"OCA\\Libresign\\Migration\\Version2040Date20211027183759","type":"->","args":[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\DB\\ConnectionAdapter"},{"__class__":"OC\\Files\\Node\\LazyRoot"},{"__class__":"OCA\\Libresign\\Service\\PdfParserService"}]]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OCA\\Libresign\\Migration\\Version2040Date20211027183759"}]},{"file":"/var/www/html/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":465,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/ServerContainer.php","line":145,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":498,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OCA\\Libresign\\Migration\\Version2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":450,"function":"createInstance","class":"OC\\DB\\MigrationService","type":"->","args":["2040Date20211027183759"]},{"file":"/var/www/html/lib/private/DB/MigrationService.php","line":417,"function":"migrateSchemaOnly","class":"OC\\DB\\MigrationService","type":"->","args":["latest"]},{"file":"/var/www/html/lib/private/Installer.php","line":154,"function":"migrate","class":"OC\\DB\\MigrationService","type":"->","args":["latest",true]},{"file":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","line":451,"function":"installApp","class":"OC\\Installer","type":"->","args":["libresign"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":225,"function":"enableApps","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":[["libresign"],[]]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":133,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":172,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"enableApps"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":298,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AppSettingsController","enableApps",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},["settings.AppSettings.enableApps"]]},{"file":"/var/www/html/lib/base.php","line":1023,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/apps/enable"]},{"file":"/var/www/html/index.php","line":36,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"vziVWkwWl4lekzN3CaXP","level":3,"time":"2022-08-25T17:10:23+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"fsockopen(): Unable to connect to 127.0.0.1:8888 (Connection refused) at /var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php#199","userAgent":"--","version":"24.0.4.1","exception":{"Exception":"Error","Message":"fsockopen(): Unable to connect to 127.0.0.1:8888 (Connection refused) at /var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php#199","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"fsockopen(): Unable to connect to 127.0.0.1:8888 (Connection refused)","/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php",199]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":199,"function":"fsockopen","args":["127.0.0.1",8888,null,null,0.1]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":171,"function":"portOpen","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":[]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":65,"function":"wakeUp","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":[]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":142,"function":"getClient","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":[]},{"file":"/var/www/html/custom_apps/libresign/lib/Service/AdminSignatureService.php","line":66,"function":"health","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":["http://127.0.0.1:8888/api/v1/cfssl/"]},{"file":"/var/www/html/custom_apps/libresign/lib/Command/Configure/Cfssl.php","line":120,"function":"generate","class":"OCA\\Libresign\\Service\\AdminSignatureService","type":"->","args":["Heath Management Solutions Ltd.","GB","Heath Management Solutions Ltd.","Heath Management Solutions Ltd.","http://127.0.0.1:8888/api/v1/cfssl/","/mnt/ncdata/appdata_ocnjvnr5owk2/libresign/cfssl_config/","1"]},{"file":"/var/www/html/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OCA\\Libresign\\Command\\Configure\\Cfssl","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/core/Command/Base.php","line":168,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"OC\\Core\\Command\\Base","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OCA\\Libresign\\Command\\Configure\\Cfssl"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->","args":[]},{"file":"/var/www/html/occ","line":11,"args":["/var/www/html/console.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
{"reqId":"vziVWkwWl4lekzN3CaXP","level":3,"time":"2022-08-25T17:10:23+00:00","remoteAddr":"","user":"--","app":"PHP","method":"","url":"--","message":"fsockopen(): Unable to connect to 127.0.0.1:8888 (Connection refused) at /var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php#199","userAgent":"--","version":"24.0.4.1","exception":{"Exception":"Error","Message":"fsockopen(): Unable to connect to 127.0.0.1:8888 (Connection refused) at /var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php#199","Code":0,"Trace":[{"function":"onError","class":"OC\\Log\\ErrorHandler","type":"::","args":[2,"fsockopen(): Unable to connect to 127.0.0.1:8888 (Connection refused)","/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php",199]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":199,"function":"fsockopen","args":["127.0.0.1",8888,null,null,0.1]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":188,"function":"portOpen","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":[]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":65,"function":"wakeUp","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":[]},{"file":"/var/www/html/custom_apps/libresign/lib/Handler/CfsslHandler.php","line":142,"function":"getClient","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":[]},{"file":"/var/www/html/custom_apps/libresign/lib/Service/AdminSignatureService.php","line":66,"function":"health","class":"OCA\\Libresign\\Handler\\CfsslHandler","type":"->","args":["http://127.0.0.1:8888/api/v1/cfssl/"]},{"file":"/var/www/html/custom_apps/libresign/lib/Command/Configure/Cfssl.php","line":120,"function":"generate","class":"OCA\\Libresign\\Service\\AdminSignatureService","type":"->","args":["Heath Management Solutions Ltd.","GB","Heath Management Solutions Ltd.","Heath Management Solutions Ltd.","http://127.0.0.1:8888/api/v1/cfssl/","/mnt/ncdata/appdata_ocnjvnr5owk2/libresign/cfssl_config/","1"]},{"file":"/var/www/html/3rdparty/symfony/console/Command/Command.php","line":255,"function":"execute","class":"OCA\\Libresign\\Command\\Configure\\Cfssl","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/core/Command/Base.php","line":168,"function":"run","class":"Symfony\\Component\\Console\\Command\\Command","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":1009,"function":"run","class":"OC\\Core\\Command\\Base","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":273,"function":"doRunCommand","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"OCA\\Libresign\\Command\\Configure\\Cfssl"},{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/3rdparty/symfony/console/Application.php","line":149,"function":"doRun","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/lib/private/Console/Application.php","line":211,"function":"run","class":"Symfony\\Component\\Console\\Application","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Input\\ArgvInput"},{"__class__":"Symfony\\Component\\Console\\Output\\ConsoleOutput"}]},{"file":"/var/www/html/console.php","line":100,"function":"run","class":"OC\\Console\\Application","type":"->","args":[]},{"file":"/var/www/html/occ","line":11,"args":["/var/www/html/console.php"],"function":"require_once"}],"File":"/var/www/html/lib/private/Log/ErrorHandler.php","Line":92,"CustomMessage":"--"}}
I canāt see anything that is related to the Request Approval piece.
Hope this helps
