Hi there, is there a way to have repeating issues /tasks that can be edited or marked as solved like in Jira ? Thanks for any help is appreciated, Frank
Check-out the Nextcloud app store and especially the Deck app. I will most likely provide the functions you’re looking for.
Thanks for your reply, but this is exactly missing. I cannot find any option to repeat an issue in the future to have a weekly or monthly task. Maybe I´m missing something here.
F
