So i have an “interesting” Problem. Similar to this post. I’m running the NC AIO Docker Version. At some point the AIO Master Docker container stopped and was eventually cleaned up by my script. I don’t have a Volume of the old AIO Docker remaining… When i start a new AIO Docker Container it doesn’t connect to the existing NC Containers which are all still running.
Now I’m wondering if there is a way to start a new AIO Container but connect it to those NC Containers which were created by my deleted Container?
Thanks for all the help in advance. I get that i boned myself with this one…
Thanks @szaimen! Of course i didn’t save a backup of the AIO Container. So I’ll have to reinstall a new NC. Definitely learning from this mistake!
One last question about the migration.md: I’m not worried about my data as i mount it into NC. But some of the config options, like i set up ldap will be lost anyways right?
Thanks again for the super quick answer and everything!
