Remote monitoring of CPU parameters
Good day,
I’m running nextcloudpi os on my network with good success so far.
I just installed this monitoring setup on a RPi5 I have and Home Assistant sees everything ok but when I repeated the operation on the nextcloud device the results all report as “unknown”
I’m wondering if the file structure is different and needs to be tweaked somehow ?? so MQTT is seeing the RPi but not able to take the readings.
